The simplistic Salas low voltage shunt regulator
Old 6th June 2012, 08:30 PM   #5101
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Cuts a lot of base current and worsens spec.
Old 6th June 2012, 08:34 PM   #5102
Salas's Avatar
Mosfet has almost no gate current but more capacitance so it needs higher gate stopper to bring the two versions in comparable Bode open loop gain plot for zero point phase margin. Its good it worked for you in a completely different layout also. No worries about the old blocking part, I do worse mistakes all the time. Regards.
Old 7th June 2012, 03:34 PM   #5103
agussug is offline agussug  Indonesia
My Regulator based on Salas Shunt Regulator
Old 7th June 2012, 04:31 PM   #5104
Salas's Avatar
What are the differences? Just custom layout?
Old 7th June 2012, 11:15 PM   #5105
Yes, just custom layout for PCB. Thank you very much for the schematic. It's sound wonderful.
regards
Old 8th July 2012, 02:36 PM   #5106
studiostevus is offline studiostevus  Netherlands
Funny stuff here... My 4 salas shunts seemed to be working correctly.... However one of them has a problem: the bc547 gets really hot and eventually burns (after several hours)
Specs:
Bib version, but on my own pcb, using irf610 for ccs and irf620 for shunt
Vout=15v
Vin=25v
Ccs=130mA
Iload=50mA tda1541a
Any ideas?
The other 3 regs on the board (5v, -5v, 3.6v) all work fine
Old 8th July 2012, 02:46 PM   #5107
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Could you post a pic?
Old 8th July 2012, 02:55 PM   #5108
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 8th July 2012, 02:56 PM   #5109
Better one with all components side & the other one with all solder junctions.
Old 8th July 2012, 03:05 PM   #5110
How's this?
Note that there are positions for some caps which are not used. Also I have connected the collector of the BC547 (depicted on the picture as BC550) to GNDplane. For the rest this is accurate.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
