The simplistic Salas low voltage shunt regulator
Old 6th June 2012, 07:18 PM   #5091
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Saved it, will look into it a bit later. Thanks.
Old 6th June 2012, 07:53 PM   #5092
studiostevus is offline studiostevus  Netherlands
Note that one leg of the bc547 is connected to the gnd plane for s0
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 6th June 2012, 07:56 PM   #5093
Salas's Avatar
What you use for output? MKT+1R or Muse + jumper in place of 1R? I see both.
Old 6th June 2012, 08:00 PM   #5094
Salas's Avatar
What is that 100R in series with an output node?
Old 6th June 2012, 08:14 PM   #5095
Output = MKT (wima 3.3uf) + 1R
BIB C101 = Muse 220uF
Old 6th June 2012, 08:16 PM   #5096
eeehm
Old 6th June 2012, 08:18 PM   #5097
Salas's Avatar
Maybe that one drops your Vo when you load up the reg?
Old 6th June 2012, 08:21 PM   #5098
Salas's Avatar
So the upper Muse on your board the one near the MKT is a missing option in the actual build? Then it would be OK.
Old 6th June 2012, 08:24 PM   #5099
yes that's correct (for a tda1541a)
And, if you don't mind, I will sit in a corner being ashamed of myself now for a bit....
The 100R was a remnant from an earlier regulator I replaced with the your reg... without it, everything seems a-ok...
Old 6th June 2012, 08:25 PM   #5100
By the way, what is the impact of using a higher base/gate stopper on a BJT (270R) ?
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
