#5021 |
Post5019
Now reduce the loop area of the main current flow route. Squeeze the sense lines as close as possible (low loop area). |
#5022 |
Now really tight (as p2p goes).
PS: Does anyone know this supplier ? outillage.e44.com E44-Eurocard motif centronix/sub-d - 100x160mm - fr4 (1pc/bl) à 5,00 ?[productImages]/0/
RC |
#5023 |
Hello there
Im noob here Please advice.... Im currently building a CMoy with salas shunt reg for PSU I've got the board from CRT ( thank to him ) But when i done soldering, it didnt worked well.... Im using transformer 50vac, 2x15v And im using MSR860 diode, resistor 10R 5 watt I only got 9.7v from V- But V+ is zero.... Please advice.... ![]() ![]() ![]()
#5024 |
diyAudio Chief Moderator
#5025 |
I see a bunch of voltage reference leds not emitting. See if you got one or more of them wrongly orientated or dead from too hot an iron or long soldering. If your meter can light an led in diode mode just test them one by one with same and correct in circuit polarity without removing them first. If meter can't, use a 9V battery fast.
#5026 |
Use a 9V battery and a 1k resistor.
#5027 |
What are the news of the made in Japan low voltage mod Reflektor? Worked stable in the end for all there? Did it bring goodness to music? I encourage our Japanese friends to write their story here too, and show some pictures if they have also.
#5028 |
Dear Salas,
I want to build your shunt regulator with this schematic for +5V output for my DAC ![]() I use PCM1798 and CS8416. Can this regulator maintain +5V on its output as PCM1798 and CS8416 greatly vary in current requirement as the sampling frequency change? For 44.1KHz, PCM1798 require about 25mA, CS8416 require about 14.5mA. For 192Khz, PCM1798 require about 45mA, CS8416 require about 40.5mA. I usually play different sampling rate music files with my DAC. Best Regards |
#5029 |
Make R1=22R and don't use C6.
#5030 |
Everyone,
Did anyone ever built a SMD version of the SSLV? What about: - Component choices (MOSFETS, resistors, caps) - Layout considerations I would very much like to learn from others before building.... thanks |
