#5001 | |
diyAudio Chief Moderator
#5002 |
Those guys look more flexible maybe. ComponentsMAX
#5003 |
#5004 |
Another question: what is recommended capacitance in the filter before Salas Reg ? I thought to go with muscular 10.000 uF but I am not sure whether that is a good approach ...
#5005 |
10uF seems far too low for smoothing capacitance.
2200uF would be nearer the smoothing requirement. |
#5006 |
10mF I guess he meant. 4700uF is a good mid value.
#5007 |
I will use 5kr for Vref // 10uF MKT on my p2p BiB clone, with three leds on the CCS.
Planning to use a 18VAC TX 50VA to get 14VDC out from the shunt. Now I would apreciate your comments on the components connections so my build goes swiftly. Does anyone detect any errors ?
RC |
#5008 |
The sense circuit is a measuring bridge.
The -sense (GND) on you drawing feeds a bridge node on the S PIN of the jFET. Is that the correct place for the bridge node? The +sense feeds a string of 4 components. Where is the bridge node? BTW, I recommend changing the GND labels to - (or -ve, or NEG) |
#5009 |
Thank you for your input Andrew.
Please forgive my lack of knowledge... What do you mean by bridge node ? I compared this layout carefully with the BiB schematic and do not detect any errors... Would you please elaborate ? Regards Ricardo
RC Last edited by RCruz; 3rd May 2012 at 12:26 PM. |
#5010 |
Are you familiar with a Wheatstone Bridge?
Look at an example. It is usually arranged as a diamond layout. The top node and the bottom node are where the voltage is applied. The side nodes are where the "error" is measured. The the ratio of resistances on each of the two sides are compared. If the ratios are identical then the "error" voltage is also zero. A small change in the resistance of any one of the four legs/sides of that diamond will change the ratio on that side. Then you can measure the "error". Using the schematic you have posted. I can see that for output X102-4 is connected to the bottom voltage. One could either choose the Source PIN of Q103, or the Emitter PIN of Q104, or the unlabeled junction between these two PINs. The Gate of Q103 must connect to it's Source PIN or to the measuring node. It must not connect to the other side of the voltage node, i.e. not to the Emitter PIN. But when you come to look at X102-3 there seem to be 6 locations for the voltage node. One must consider where the AC and DC currents flow and pick the node that best inserts the voltage so that the ratios are correctly measured. Similarly when one comes to consider the side to side measuring Nodes, one must find the nodes that properly reflect where the error is correctly measured for both AC and DC outputs. This is not a "pin the tail on the donkey" exercise. This is precisely where the original DCB1 went wrong and some of the later incarnations were also wrong. It took many posts, pointing out the mistaken layout, before the Members realised what they were doing wrong. Last edited by AndrewT; 3rd May 2012 at 04:34 PM. |
