The simplistic Salas low voltage shunt regulator - Page 50 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th June 2009, 01:42 AM   #491
Nico,
Try substituting the BYW29s for the Stealth diodes, maybe change up the Kgs for F&Ts, Mundorfs, etc and perhaps see about changing the wire, too.
Sounds a bit crazy but it's quite surprising how these small things add up - an R-C-R-C arrangement, the simple Haggerman snubbers, good wire, cool diodes, reistors, etc
Old 13th June 2009, 01:50 AM   #492
thanks !
Or new Salas shunt for pwstage
Old 13th June 2009, 02:17 AM   #493
Tham is offline Tham  Malaysia
Hi Salas,
The smoothing caps are just two 1000uF Rubycon YXA bypassed with a small polystyrene cap that I have on hand.
Old 13th June 2009, 02:56 AM   #494
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You can go up to 10.000uF. Panasonic TS-HA are good value.
Old 13th June 2009, 03:01 AM   #495
Thanks. Will try that later.
Old 13th June 2009, 03:34 AM   #496
iko is offline iko  Canada
iko's Avatar
Originally posted by nicoch46
t ambient is 28... better put some hole in the pcb
fak** toroid 65VA 40v, put out 57vdc with 400ma shunt current!!!
are you dissipating over 20W just in the shunt?
Old 13th June 2009, 08:51 AM   #497
the zone near zener end up to 40 ,the body is at 45
Originally posted by AndrewT
what power is the Zener dissipating ref. maximum power rating?
Originally posted by Salas
300-400mW for a 1W part in nicoch case.
try reducing the current through the Zener to get dissipation down to ~100mW.
Or change the Zener to a 400mW type and reduce dissipation to ~50mW.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th June 2009, 03:15 PM   #498
iko I have four shunt at 100ma , 2x +/-
Old 15th June 2009, 03:38 AM   #499
staggerlee's Avatar
We also need to thank James for his PCB efforts.
Here is his latest refinement for V1. He has included every possible nut n' bolt. LEDs CCS, Vbe CCS, positive / negative shunt, Zener socket for changing Vout in a sec, clean, compact, star layout. I did not see anything wrong by looking at it, you may have your second look too. James is more suitable to comment on the options and how to implement them I guess. He has also made a few V1s (not in WWII) and maybe he can convey his experiences and applications if he likes to.
James/Salas,
First off the layout of this board is stunningly elegant. Just fantastic! Is this compatible with the schematic in post 1, which I believe is V1 with the R6 Mod?
Old 15th June 2009, 04:08 AM   #500
Hi Iko,
Will try the version in post #456...for18Vdc output, do I change both the zeners to 18V diode? Any other changes need to be made?
Copyright 1999-2017 diyAudio
