The simplistic Salas low voltage shunt regulator
Old 3rd March 2012, 09:49 PM   #4841
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by pidesd View Post
i also remember having read multiple times that it is desirable to match parallel output devices in the output stage of amps but i m not sure why...could you (or someone else) care to explain? i understand that heat load will be shared even but that is it...
also, i understand that having the lowest possible bias through the bjt (see pic) gives lower output impedance, so i m wondering what obstacles do you encounter when lowering to much the bias. is there a sweet spot? in the pic it is around 4mA depending on the mosfet.
To avoid current hogging that leads to a catastrophic sequence.
The output impedance will be a function of the error amp's open loop gain and the current follower's transcoductance. R6 gets to be a CCS and the follower's bias gets to be spared higher to trigger more Gfs if we are after decreasing Zo.
Old 3rd March 2012, 10:56 PM   #4842
pidesd is offline pidesd  Canada
pidesd's Avatar
you mean that we dont want to be in the bottom portion of the graph in the attachment, where linearity is not so good?
yes i just remembered that a jfet had replaced the resistor in the later versions.how about 2 jfets cascoded to further improve Zo?would you advise against it or should i let myself go?
P.S.: just tell me if i get annoying with my questions and i ll get back to my books
Old 4th March 2012, 01:00 AM   #4843
Salas's Avatar
We don't want one in a group to draw more current than the others, as it gets hotter it draws even more, vicious circle until it fails and kills some more. So we match them and/or we give them little source resistors like in amps.
To make a cascode is not recommended when you will only have 3.3V and in there you will have to fit one vbe and two Vgs drops. Use a BF245A, its enough low pinch off and low capacitance Jfet good for VHF/UHF amps even.
Old 4th March 2012, 02:13 AM   #4844
pidesd's Avatar
yes indeed, fitting a cascode within around 2.5V 2sj313 Vgs looks pretty lame. forgot about that .
thanks for showing me bf245a looks better than 2sk170. looks also like it would require very low current to be effective. maybe something like the less available 2sk369 would be a better fit(although capacitance is higher...)?
Old 4th March 2012, 08:31 PM   #4845
pidesd's Avatar
after giving some thought, bf245a might be very nice as current sources in this reg indeed.now i ll try to find a more common shunt mosfet.
thanks a lot salas. now i know better what direction to go to.
Old 4th March 2012, 08:43 PM   #4846
Salas's Avatar
Whatever sum of parts you choose see they will have adequate phase margin for stability as a circuit. Good luck.
Old 6th March 2012, 02:54 PM   #4847
back is offline back  Greece
guys the output mosfet is hot when testing without load and colder with load?
is that correct?
Old 6th March 2012, 02:57 PM   #4848
Salas's Avatar
Correct.
Old 8th March 2012, 04:17 AM   #4849
pidesd's Avatar
ok. i might just not venture into paralleling shunt devices yet.
what do you think about those?
fqp4n20l
http://media.digikey.com/pdf/Data%20...s/FQP4N20L.pdf
zvn0124a
http://www.diodes.com/datasheets/ZVN0124A.pdf
IRLU024Z
http://www.irf.com/product-info/data...rlr024zpbf.pdf
Old 8th March 2012, 11:01 AM   #4850
pedefede is offline pedefede  Denmark
For 1,2V "disco" (about 150mA):
would it be possible (and benificial) to substitute the v1 "CCS-section" with bc560; - to v1.1 bib with 3 green led? (Then you actually could tweak the bib-board, by mainly substituting the MJE15031 for d45h8 (+ jumper bib-R4, and bib-R6 = 10ohm)
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
