#4821 |
Thanks, will do.
... jh |
#4822 |
I am building a disco 1,2V for DAC
- would you also recommend 2SK117 here (instead of 2sk170) as in bib?? - what mA should i aim at, for the idss at Q5 in error-circuit? (low as possible?) peter Last edited by pedefede; 21st February 2012 at 02:09 PM. |
#4823 |
diyAudio Chief Moderator
They can be used also but be GR. Q5 lowest IDSS in your batch, yes.
#4824 |
sourcing components...
What would make a good resistor for psu (used for DAC) 1) smd ? (for short signalpath) 2) nonmagnetic ? 3) noninductive, noncapacitive ? 4) Else? |
#4825 |
Low ppm.
#4826 |
Low TCR
#4828 |
#4829 |
Temperature Coefficient of Resistance (TCR) is expressed as the change in resistance in ppm ( .0001%) with each degree of change in temperature Celsius (Co). This change is not linear with the TCR the lowest at +25oC and increasing as the temperature increases ( or decreases). It can be either a bell shaped curve or an S shaped curve. It is treated as being linear unless very accurate measurements are needed, then a temperature correction chart is used. Normally a resistor with a TCR of 100 ppm will change 0.1% over a 10 degree change and 1% over a 100 degree change. The expression of ppm , one part in a million is similar to percent or 1 part in 100 (or percentile)
RC |
#4830 | |
