Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th February 2012, 11:41 PM   #4801
Bksabath's Avatar
Originally Posted by Salas View Post
Not higher than 200mV pk-pk ripple would be nice.
I tried a comon mode coke made up with 2 wires wound up togheter on a coil
at the output of a LM317 regulator and it did make big difference
Maybe is worth a try and compare impressions?
Old 10th February 2012, 11:49 PM   #4802
krivium is offline krivium  France
It should be doable.
I like the idea to have lesser heat on M1 and better prefiltering.
Thank you very much Salas!
Regards.
Old 11th February 2012, 12:16 AM   #4803
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Common mode is always nice because it cleans up ground too.
Old 16th February 2012, 01:01 PM   #4804
Salas congrats for your skill and thank you for your amazing contributions. I have been reading your threads like crazy during the past few days, and I must say I am impressed of the work that you and others have put into these circuits.
At the same time I feel completely overwhelmed by information since I cannot understand everything (being a semi-ignorant diy dude), and running through the entire threads can be very tedious.
Could you please give me your opinion on using the reflektor (or any other variant of your PSUs) to power the motor of a Technics SL1200 MK2?
The turntable requires 21V at ~500mA peak.
Old 16th February 2012, 03:08 PM   #4805
Salas's Avatar
Don't know what the motor may give it for phase stability as a load, you gotta try it to see it will do OK, since nobody had used on MK2 before so to tell you what's gonna happen. The Reflektor is the simplest to make and gives steady voltage easily. Use 1 Ohm R1 and BF245A without source resistor if you haven't got K170. No more than 30Vin and 2C/W common sink for the (insulated) Mosfets.
Old 16th February 2012, 04:19 PM   #4806
I expected something like that about the motor. I tried to edit the post to make a correction but the 30minutes had passed
I do not plan to power the motor directly. More of its driving circuit instead, so I don t think it would be much of a problem as a load.
I found a big bunch of 2SK170BL yesterday rated at between 6 and 10 mA so I guess I ll be fine using them (I hate waiting for stuff....)
Old 17th February 2012, 02:20 AM   #4807
Hi Salas,
Can you suggest me which one Shunt reg suitable for Pumpkin Pre-Amp (+/- 24V, 150mA) and for Aleph 1.7 (+60V, 200mA)?
Didiet
Old 17th February 2012, 02:57 PM   #4808
jackinnj's Avatar
They are output impedance traces versus frequency. Dotted is their phase. You can read the one I posted before in dB, also in Ohm as such (~7mOhm flat portion):
My (actual) Salas is better than your (simmed) Salas:
Salas BIB with IRF HexFETs.
Old 17th February 2012, 03:21 PM   #4809
nicoch58's Avatar
the Technics SL1200 don't use a sort of elettronic feedback for control the speed ?
Sic58
Old 17th February 2012, 03:40 PM   #4810
Salas's Avatar
With how much CCS current? Standard bib 9610,9530,Zobel termination? Looks like there is more Gfs and Ciss than in the shunt hexfet model? *7mOhm was referencing the reflektor
Page generated in 0.13300 seconds (57.22% PHP - 42.78% MySQL) with 11 queries
