The simplistic Salas low voltage shunt regulator
Old 5th February 2012, 06:10 PM   #4781
mns80 is offline mns80  Finland
Originally Posted by Salas View Post
Mats, its just down to your aspirations VS investing in time and parts. The law of diminishing returns rears its ugly head at a point. All the difference is at what point you are content. A prudent way is to go step by step and try to stop when differences start to seem like too much complication for nothing to you.
I understand your point. I was also thinking about if I actually win anything on doing supplies for each channel separately. I think I'll make the pcbs and test, if the cooling on the powersupply box is sufficent and the xformers keep cool I'll do 6 shunts and if not I'll use one per voltage. Either way, thanks for your time!
Best regards,
Mats
Old 6th February 2012, 06:10 PM   #4782
R.I.P.
One big CCS feeding a resistor for each client circuit.
After the resistor fit the Shunt regulator right on top of the client circuit.
regards Andrew T.
Old 7th February 2012, 12:11 AM   #4783
carlmart is offline carlmart  Brazil
Originally Posted by mns80 View Post
First I tried it out with a CRCRC+317 to get some kind of a feel, sound was good but there was too much noise
Just to be fair to the 317, which I have used very often with very good results:
1) Have you bypassed the adjust leg (100uF to 220uF)?
2) Have you used a not so low-ESR cap at the output, no larger than 220uF?
3) Have you loaded the output with a 100 ohm resistor?
The first one will improve impedance and improve noise (look for Walt Jung comparison measurements on his super-regulator articles).
The second will prevent oscillations for low-ESR caps and/or large caps, and lower noise.
The third seems to improve things all around.
Then I think comparisons can be made, considering parts quantity is quite small on a 3X7 project.
Old 7th February 2012, 12:34 PM   #4784
pedefede is offline pedefede  Denmark
Avoid Schottky diodes in the Vref (1A to go 0.6V)...
I am building some 1,2V Disco-versions (post 1616) for DAC:
1) Is there any better version than in post 1616?
2) I wonderd if there was any possible substitute to a resistor/pot (above the CCS Q5). It could be a diode with low Vf like Schottky - but is that a bad idea? If yes - can you get any (low noise) lower Vf than an ordinary silicium diode like 1N4004 of 0,6V ??
3) Christel in his noise-measurements in
http://www.diyaudio.com/forums/parts...er-diodes.html
and
http://www.diyaudio.com/forums/attac...amp=1087235682
meantioned a "BC549 BE diode forward biased transistor" (as even more quiet than LED). Does anyone have a schematic how that connection is done?
Peter
Old 7th February 2012, 12:37 PM   #4785
R.I.P.
Connect base to collector.
It is now a two terminal device that behaves like a diode.
regards Andrew T.
Old 7th February 2012, 03:30 PM   #4786
Thanks for the suggestions! I had not done 1 and 3 and for the 2nd one I only had some 10uF at home.
Just now I tested with 220uF bypass and 170R load in addition to the 3pcs10uF but I did not notice any improvement. I have to admit that my testing abilities are not more than my hearing as i do not own an oscilloscope. This means I tested and compared the shunt/317 and the suggestions driving phono stage with the preamp at full blast after and there was a big difference.
I do not mean to say anything bad about the 317, it most certanly has its applications, but comparing the noise this way the 1.2R sounds a lot better (less).
Old 7th February 2012, 03:37 PM   #4787
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by pedefede View Post
I am building some 1,2V Disco-versions (post 1616) for DAC.......
Peter
1. No
2. Use a normal diode 1N4003 or ''dioded'' BJT.
3. Andrew replied.
Old 7th February 2012, 03:39 PM   #4788
Salas's Avatar
Mats:
You did not show your MM phono in its thread yet, yes? Take some pics and show there if you may, a few make MM version, maybe they wanna know details.
Old 7th February 2012, 03:48 PM   #4789
Mats:
I could try take some pics later this evening of the nice breadboard I have. I started drawing some schematics in eagle last night to prepare for some PCB layout but it will probably be some weeks before I get all the parts, not ordered yet for the shunts, and the PCBs made.
Old 8th February 2012, 11:02 AM   #4790
Solushunz is offline Solushunz
I love this excellent feedback with have good opinion.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
