Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
#4761 | |
Regarding post #4703 the Reflektor board layout, I don't see cap C1. It shows 1uf on the schematics. What type of cap should it be? MKP? C3 on your schematic shows as C4 on the board should it be MKP? And C2 1000uf panasonic FM ok? Best Ken |
#4762 |
diyAudio Chief Moderator
MKP in the RC across the output. C2 FM OK. Board has its Eagle designations (C1+). There is up to C3 only, which is the included rectification's filter capacitor.
#4763 |
#4764 |
Will post here again, from Eagle so you can picture it easier. M2 is a Mosfet also, BJT symbol used for library reasons, same for J1, is a JFET. Rectification of two type diodes choice and filter capacitor are also on board.
#4765 |
Thank Salas,
It's a bit different from post #4287. Ken |
#4766 |
It misses a snubber across C2 to the first inception that after subjective evaluations of members was judged not adding much. So it got even less parts count. Has a trimmer for adjustable Vo instead of R6 also.
#4767 |
I have Pro Ject Phono Box SE II and I want to make external power suplay.
I need 16V 215mA suhunt regulator. Which version of salas shunt regulator would you recommend? |
#4768 |
Any. Reflektor and SSLV1.1 the easiest to make.
#4769 |
I have been "experimenting" with some pre amps and phono amps and have settled on the ones I'd like make or already have made. The phono will be the 37dB Salas simplistic RIAA as per the pdf, at the moment on breadboard. First I tried it out with a CRCRC+317 to get some kind of a feel, sound was good but there was too much noise so just for fun I tested the V1.2R up to 45V on a breadboard. What a difference, totally silent and the sound is soo much better! The preamp then is a slightly modified version of the cascoded jboz that Juma posted in the Jfet BOZ thread which sounds great. I tried some other versions too but did not like them as much.
As the RIAA sounded that much better with one shunt for 2 channels I was thinking of doing shunts for all the supplies, 2pcs for 40V (preamp), 2pcs 24V for the RIAA and 2pcs for the -3.5V (preamp). I have one transformer 2x40V 150VA and one transformer 2x12V 80VA. For the 40V and 24V I was thinking of using the 150VA 40V transformer and for the -3.5V the 80VA 12V. Do you think this will be too much for the transformers or too overkill for the application that I am thinking of or do you have any other comments? Regards, Mats |
#4770 |
I decided to bulid salas SSR1.1.
I read SALAS REG SSR v1.1 BIB GUIDE REV2 But because of my poor English and poor knowledge of electronis I need a little help. My Pro Ject Phono Box SE II need 215mA + 70-150mA excess max load-350mA. DC in is 26V and V-out 16V. I use calculator from salas but I would love someone to just check the value of R101,201- 10,2 ohm R103,203- 2500 ohm R105,205- trim 550 ohm Is it o.k!? |
New To Site? | Need Help? |
