The simplistic Salas low voltage shunt regulator
Old 25th January 2012, 05:48 PM   #4731
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No in general, 1.1BIB in GB for pcbs sometimes here in DIYA, but you missed last one by a week late. Make reflektor on matrix board its the easiest.
Old 25th January 2012, 05:50 PM   #4732
Salas's Avatar
Originally Posted by krivium View Post
i have acces 2sc2240 or bc 639. Are they ok?
Only if you can cool Q3 with TO-92 minisinks. Its a matter of dissipation for that high Vout. The others in the current mirror don't suffer as much voltage drop.
Old 25th January 2012, 05:58 PM   #4733
carlmart is offline carlmart  Brazil
My problem is sourcing the parts from Brazil can be difficult and expensive.
If I can get all the parts from one place, then projects can be accomplished.
Old 25th January 2012, 06:18 PM   #4734
Salas's Avatar
Reflektor has the easiest parts. Almost any pnp transistor type and two very well stocked mosfet types. For its Jfet you can use many types. State the application (Vout, current, type of machine) so I can give you more precise info.
Old 25th January 2012, 06:43 PM   #4735
Reflektor is a company? I couldn't find it in Google.
I should be buying a JC-2 preamp kit in eBay this week, and it does carry a shunt supply on-board. So I thought I might replace it with a better shunt, and I thought of yours. What do you think?
Old 25th January 2012, 06:58 PM   #4736
R.I.P.
CCS followed by a Shunt reg.
Exactly the same principle of operation as the Salas Shunt reg.
regards Andrew T.
Old 25th January 2012, 07:03 PM   #4737
The principle might be the same... but the details are different!
Old 25th January 2012, 07:07 PM   #4738
Salas's Avatar
Start with that one and get a 1.1 BIB at a point when there will be another GB if you are ready made PCB minded. Then you can tell for differences yourself.
*Reflektor is one shunt design of mine based on current mirror principle.
Old 25th January 2012, 07:12 PM   #4739
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Yes.. no mosfets and a zener for Vref .... you will be astonished when you build the bib
RC
Old 25th January 2012, 07:13 PM   #4740
Salas's Avatar
TL431 is a chip, but it can be as noisy depending on Ik it runs.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
