The simplistic Salas low voltage shunt regulator
Old 14th November 2011, 03:11 PM   #4641
milen007 is offline milen007  Indonesia
i cant find the link where i save the schematic so i just attached it
thanks,
erwin
Old 14th November 2011, 03:17 PM   #4642
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What do you want to change: output lytic cap 220uF for a MKP film 10uF?
Old 14th November 2011, 03:24 PM   #4643
hi Merlin
yes. i wondering if i could use 10uf instead of the 220uf on the schematic? or whats the min value should be place at the output of the salas board. as the supplied board already has 220uf on the input
thanks in advance
erwin
Old 14th November 2011, 03:36 PM   #4644
Why do you want to change, depending application it's better lytic, it's intended for digital or analog?
Old 14th November 2011, 03:40 PM   #4645
hi Merlin
its for analog dac out. i am just wondering if i could change it to 10uf with better quality cap on salas board. instead of 1 pcs 220uf on salas side and another 220uf on the supplied circuit
erwin
Old 14th November 2011, 03:45 PM   #4646
If you have other 220uF at the load input I will say you can't use it at the regulator but lets's Salas to tell us something to be sure.
Old 14th November 2011, 05:49 PM   #4647
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi erwin
The schematic you are presenting corresponds to SSV1... it will not work with 10u on the output.
It might work with a lower value but I would not go below 47uF.
RC
Old 14th November 2011, 11:50 PM   #4648
Hi Richardo
Thanks. This is what I am looking for. Superb
Erwin
Old 15th November 2011, 08:04 PM   #4649
nhinstruments
RCruz's Avatar
Hi Erwin
Save the 10u film cap for vref.
RC
Old 23rd November 2011, 03:57 AM   #4650
Tham is offline Tham  Malaysia
Originally Posted by Salas View Post
You can just use 12V input to the V1.2R and turn the trimmer down to 5V output. Use first schematic from the left in post #3200.
Better use K170 Q8 in that when targeting 5V. Will work nicer when so low.
Hi Salas,
I have 16V input and K170 at Q8, and I can only adjust Vo to min of 10.6V. Do I need to reduce the input to output 5V?
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
