#4561 |
diyAudio Chief Moderator
The RC Zobel is local termination to the Bib and should stay local to the bib. If it can be close enough to both on dual role for decoupling the 1541 too, so much to the better. But is a 4u7 plastic capacitor enough for that chip?
#4562 | |
I would leave the output El cap OR the Zobel (MKT+ R) close to the shunt device (BJT or MosFet) |
#4563 |
Sorry Salas, we were writing a reply at the same time!
#4564 | |
If I understand correctly, this is the schematic Screen shot 2011-11-04 at 8.57.04 PM.png |
#4565 |
Yes, but no C26. That one is the ''plan B'' capacitor in the Bib.
#4566 |
#4567 |
As far as I could read earlier in the thread, the BJT version is recommended for high frequency circuits, so I would use that for my 11 MHz clock.
For the inputs on the DAC (digital, analog and analog/digital), is there a recommendation on which version to use? Certainly MOSFET for the analog supply to the chip for lowest Zo.... The digital circuits are probably better off with the bjt-version...? |
#4568 |
#4569 | |
#4570 |
