The simplistic Salas low voltage shunt regulator - Page 437 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th October 2011, 12:28 AM   #4361
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by back View Post
guys what do you use for snubber?
i use 1n5822 diodes.
i have some on hand wima mks2 0.1uf/100v
are they any good?
We don't usually. Just good rectifiers. You should be OK with your Schottky basically.
Old 7th October 2011, 12:29 AM   #4362
Salas's Avatar
Originally Posted by RCruz View Post
Second Reflektor is working perfectly
As I did not find any IRF9610 I used one SFP9610.
Fine. SFP looks a bit more capacitive, but not alarmingly so. You are building a symmetric right? So the negative must be IRF610 and NPN TO-92 in the CCS. Any pictures yet?
Old 7th October 2011, 01:24 AM   #4363
Salas's Avatar
Trimming after it is hot provides very stable 10.00Vout.
What seems strange is that when powered from cold, it takes 10 seconds to reach 10.13Vout and then starts to go down. It takes 10 minutes to stabilize at 10.00Vout.
In all my other regs the voltage only goes up until it stabilizes.
I will now build a second shunt so I can test them in my p2p DCB1.
That should be the NTC action of the LED. This is not analogous to the other regs at all. Has no JFET controlled by Vbe. 1.3% travel looks fine for a dirt cheap LED and resistor Ref and so many silicon junctions in the Wilson. No wide drift safety issues. Negative drift is safe to the load even if it was much more. Imagine if using it for an op-amp on the verge of its max allowed PSUs. Could be even better if the trimmer gets to be a low ppm resistor finally.
Old 7th October 2011, 12:01 PM   #4364
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Default REFLEKTOR 1
The second build is also positive as I am using a TX with double windings and double rectifier bridges.
Yesterday I replaced the V1 with the Reflektor shunts in the DCB1 and now I am waiting for everything to settle (I believe solder joints neet to mature and some caps need some time to give their best).
Inittiall impressions are: Very silent operation, very stable + - 10V reached quite fast.
Trebble detail and transient presentation are quite good but I need to wait a while to be able to evaluate properly.
Some pics:
RC
Old 7th October 2011, 12:07 PM   #4365
nhinstruments
RCruz's Avatar
The big cap to the left is an input cap.
Vref cap is a 680uF BGN bypassed by a zobel (025r + 3u3 AudynCap QS)
Output zobel is 2r2 + 1u.
Just to be on the safe side, I used a MCF 120r as base stopper on Q5, so I do not know if it works better without it.
Once I get a true picture of the sonic presentation, I will fine tune.
I will use the 0.2r resistors from Merlin with the 1uF to bypass the Vref cap, and I will reduce the output cap. Maybe it works with a 220nF FT-3.
RC
Old 7th October 2011, 04:37 PM   #4366
Salas's Avatar
OK. Nice constructions. Good it works robust without technical problems from get go for a beta circuit.
Old 7th October 2011, 05:33 PM   #4367
nhinstruments
RCruz's Avatar
Yes.... Robust operation, very easy to trim Vout, settles on desired output almost from the start only with minimal deviations (6 seconds to reach 10.13V and 10.00V after 7 minutes).
Output offset on DCB1 changes only 0.1mV from cold start untill it settles on the final values.
After running all night and listening to radio for 4 hours in the morning, I started critical listening in the afternoon and my first impressions are quite positive.
Extended and clean trebble, powerfull rendition of transients, good presence in the mids (particularly in wood instruments) and fully controled bass.
Also very quiet, presenting lower hiss than V1.
It is a keeper. A really good improvement over the "souped up" V1 I was using.
I particularly like the low parts count, low value output cap, ease of implementation, low cost and robust operation.
The only difficulty is related with matching the transistors in the Wilson Mirror. I only got two matched pairs in 40 pieces of BC560C.
Monday I plan to start modding it... I will start by the output zobel... Can I short the 2r2 ?
RC
Old 7th October 2011, 07:47 PM   #4368
keantoken's Avatar
I've heard Phillips transistors are much better matched. I heard they discontinued the BC5x0, but have better ones now anyways. I haven't looked into it much though.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 7th October 2011, 08:08 PM   #4369
Salas's Avatar
No, you can't short the 2R2, but you can see with 0.22uF Teflon instead the Zobel 1uF cap if its still stable in your application. That will extend it in frequency even more if it will remain stable. Teflon can be used for Vref large cap bypass also for the subjective thing. Nice report so far. 2N4403 as shown in the published beta REFLEKTOR CCTs is a good solution for up to 30V out also. Very cheap, very low noise. A match around 10 units hfe difference is very good for Q1,Q2 no need be absolute.
Old 7th October 2011, 09:51 PM   #4370
Sorry if it is a stupid question but is there an equivalent reflektor schema using NPN transistor instead of PNP ?
Copyright 1999-2017 diyAudio
