The simplistic Salas low voltage shunt regulator
Old 4th October 2011, 08:20 PM   #4341
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by merlin el mago View Post
What's NMOS?
It's what your avatar is.
Old 4th October 2011, 09:18 PM   #4342
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
What's NMOS?
There are two types of Mosfets:
Tipo nMOS: Substrato de tipo p e difusões de tipo n.
Tipo pMOS: Substrato de tipo n e difusões de tipo p.
RC
Old 5th October 2011, 10:50 AM   #4343
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thanks guys
Old 5th October 2011, 11:26 AM   #4344
nhinstruments
RCruz's Avatar
I bought some cheap IRF640 from a locar distributor.
I can not identify the OEM
It reads IRF640 Y03K AB
Is it possible these are fakes ?
RC
Old 5th October 2011, 11:35 AM   #4345
Salas's Avatar
They are widely made. Any photo?
Old 5th October 2011, 09:08 PM   #4346
Tazmaniac is offline Tazmaniac  France
For the REFLEKTOR, could we made a MJE variant for 3.3v Vout as for the SSLV by simply replacing the mosfet shunt ?
Old 5th October 2011, 10:01 PM   #4347
Salas's Avatar
The output impedance would be very uninspiring in that case.
Old 5th October 2011, 11:41 PM   #4348
nhinstruments
RCruz's Avatar
Just finished the Reflektor and it fired ok. Looks promising. very stable on the bench with a 1kr load.
Very easy to set voltage out.
Strangely, I set it to 10.00Vout and it is loosing voltage with time... 10.00 ~9.99 ~9.98.... As it heats up.
I will let it running for a while now.
My choice of 3r3 // 10r for R1 was spot on.... It is running at 250mA.
RC
Old 5th October 2011, 11:43 PM   #4349
nhinstruments
RCruz's Avatar
It seems the IRF640 are ok after all... I got them from a local distributor (Robert Mouser). This guy is German so I guess he only sells good stuff.
RC
Old 5th October 2011, 11:48 PM   #4350
Salas's Avatar
As it heats up some things change a little, like Vgs, Vbe(s), let it come up and then fix it with the trimmer.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
