The simplistic Salas low voltage shunt regulator - Page 433 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st October 2011, 04:58 PM   #4321
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Saturday Homework:
I want to have at least 220mA in the CCS so I am using 3r3 // 10r instead of 4r7 for R1.
R4 = 82r (I do not have such value so I will try 100r)
The 470u BG std on the input is good for decoupling.
R7 (0.22r) will be done with 4 x 1r (R7 a-d)
The output zobel cap (1u) is placed on the edge of the board so I can easily replace it (I want to try 220nF FT-3)
For C2 I will try 680u BGN that I have left over.
I would apreciate your oppinions on the layout and particularly on the Mosfet connections because I am not sure I got M2 Drain and Source well connected... Does M2 Drain go to F+ ?
RC
Old 1st October 2011, 05:28 PM   #4322
merlin el mago's Avatar
Ricardo how many 0R22 do you need?
Old 1st October 2011, 05:46 PM   #4323
nhinstruments
RCruz's Avatar
Two... at least
RC
Old 1st October 2011, 05:55 PM   #4324
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Q1,Q2 reverse so they look to each one's face so you can bond them for same temperature. See they have the best hfe & Vbe matching also.
Old 1st October 2011, 06:09 PM   #4325
Ricardo shot me an email with your full name & address I will send you a couple of Vishay vitreous enameled 0R22 3W
Old 1st October 2011, 06:14 PM   #4326
nhinstruments
RCruz's Avatar
Thank you Merlin
You have e-mail.
I have a box full of 220nF FT-3... do you want some to experiment ?
RC
Old 1st October 2011, 06:20 PM   #4327
nhinstruments
RCruz's Avatar
I will do that , thanks. What type of glue should I use ? Or can I use thermal compound and fix them with termal sleeve ?
Can I use metal film 220r for gate stoppers or should I go for CF ?
Is R3 2.2r determinant or can I use 1r8 ?
RC
Old 1st October 2011, 06:26 PM   #4328
Salas's Avatar
Gate stoppers MF OK, worked with other regs with comparable gain and frequency too. Have some space in case a base stopper for Q5 is going to be needed in the end, there is some layout distance that may demand it. No glue! Thermal grease and thin tie wrap or heat shrink sleeve.
1.8R looks safe (theoretically). If it proves very stable, we can look if it will be stable with only 220nF teflon zobel cap also. But don't start with too many changes, in case it will not go well, to know where to experiment step by step.
Old 1st October 2011, 06:47 PM   #4329
nhinstruments
RCruz's Avatar
Perfect... please have a look at the new layout (I will leave space for Q5 base stopper)
The changes I am asking for are only related with my stock of parts.
I can not buy anything now and must use whatever I have got
RC
Old 1st October 2011, 08:23 PM   #4330
Originally Posted by RCruz View Post
Thank you Merlin
You have e-mail.
Ricardo you have email, thanks for the couple of caps.
Copyright 1999-2017 diyAudio
