The simplistic Salas low voltage shunt regulator
Old 24th August 2011, 12:18 PM   #4211
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Xc @ 10Hz = 72.343 Ohm. That is //~1kOhm in the 3.3V reg. The AD797 has 100 Ohm on its input pins, its bipolar so it has some Ib over them & over the gain ones, 2.58x gain via 1.3k/0.82k Rf in that link you provided. Those are altering the best the chip can do. There is no Vref gain in the BiB, only buffering. That shines more, the more Vout we need. I measured a Muse 220uF/25V for DF, has 0.0346 @ 100Hz, 0.0358 @ 120Hz, & 0.0925 @ 1kHz. So loss is normally dropping the lower we go. The 2SK117 Vref CCS is same league with AD797 (naked, best samples) for sub 100Hz near 1kOhm source and does much better near 10kOhm (Most people here will use ~5kOhm for 15Vout). There is no input bias current or other resistors on it. You don't get a 220uF Nichicon Muse in a SOIC package silicon die, nor 500mA idle current from its embedded output transistors. All in all not too bad for a discrete it looks like for elements and configurations, can have several nVrtHz 1/f in real life and not 1nVrtHz @ 20Hz, I don't buy that either, but its a good indication its not at least overlooked for noise as far as discrete go. And you can't ask say 45V @ 0.5A from an op amp, the BiB is general purpose. AD797 quotes 50nV p-p 10Hz BW self noise, forget the network around it. I give 30x simulator error because say the models are not good for complete noise calculations. If it gives 100nVp-p noise between 1Hz-10Hz in BJT output 3.3V guise, it would be nice. If someone with a BJT output BiB has a lab grade spectrum analyzer it will be nice to measure it for us. As for the subjective part, its up to each one's liking in the multitude of combinations it can serve. Some will hate it some will like it, I already provided the fairy tales part in the thread's title, so feel free shooting it or loving it and saying it here. Personally I will be glad if it can be adequate and useful in the hands of enough people in the long term if they will feel it was worth putting it together in the end instead of sticking an LM317.
Old 24th August 2011, 04:21 PM   #4212
stormsonic is offline stormsonic  Slovenia
stormsonic's Avatar
HERE is nice opamp noise calculator to make calculations easier and also some low noise calculations.
Xc@10Hz = 72.343 Ohm and Xc@1Hz = 723.43 Ohm for 220uF lytic cap. Therefore this cap won't do anything at low frequencies, since dynamic impedance of LED's is lower.
I'm great fan of discretes and prefer them over opamps. Yes, discretes give us more creativity, higher output voltages, more current,...etc, etc,...
Quartz based clocks are one funny exception, where we need low 1/f noise and discrete based regulator won't give us optimum performance. Especially JFET's and MOSFET's with higher 1/f corner. And clocks need only 3.3V or 5V.
Old 24th August 2011, 04:26 PM   #4213
Salas's Avatar
No, there is an LED and a 1K trimmer in series. The cap will still do its stuff low enough since the trimmer will be at about 500R + LED impedance for 3mA running them. 1.9VLED at 3mA CCS what is it, 600 Ohm Z? Nice Calc BTW, tnx.
P.S. Isn't there any PSRR figure in the clocks? How sensitive they are?
Old 24th August 2011, 05:29 PM   #4214
stormsonic's Avatar
Dynamic impedance of LED is not linear and Ohm's law doesn't work here.
Up to 1.7V, LED is usually OFF and resistance is very big.
From 1.7V to 2.0V LED is ON and ratio Voltage/Current is changing in non-linear way.
From 2V and up, LED is FULL ON and dynamic resistance remains constant.
Of course, all voltages are only approximation and can be different for different LED.
Dynamic impedance of single LED should be under 50R at 3mA. Correct answers can be found only in manufacturers datasheets.
Old 24th August 2011, 05:58 PM   #4215
Salas's Avatar
Thanks for looking in to it. The LED's Z will come from DeltaV/DeltaI and charts I presume. OK, lets assume 50R. So we got a 550R Johnson noise source fed from a K117 CCS and shunted by a 220uF cap in our Merlin's example. So we must sum by square 3nVrtHz resistance noise and ~3nV rtHz @ 10Hz K117 noise. That's 4.24nVrtHz sans filtering. Though a 10Hz 72R Xc cap still affects a 550R Z even under 10Hz, lets say it has no effect. Still the fleapower AD797 arrangement gave 9nVrtHz assuming NO noise is coming in from its Vref which is an LED also with 10K and 3u3 filter, feeding 8.23dB gain. Can source 30mA. Not hands down easily better on second look.
P.S. 3.3uF=4.823k @ 10Hz & 48.3k @ 1Hz. I.e. much worse in proportion to its 10k than 72R to 550R and 720R to 550R.
Old 24th August 2011, 09:08 PM   #4216
stormsonic's Avatar
Hmm, I'm sorry, but I don't quite understand your logic. Are we talking low wideband noise or low 1/f noise?
If we are talking about 1/f noise, we must compare apples to apples.
For AD797 noise from 0.1 - 10 Hz is specified as 50 nVp-p, that is 17.68 nVrms.
Where is specified 0.1 - 10 Hz noise for JFET?
If we assume there is 3nv@10 Hz, what is at 0.1 - 10 Hz?
30 nV rms....50 nVrms...70 nVrms.....?
In BiB regulator noise from voltage reference (LED + 500R trimmer) is shunted by 220uF capacitor (bigger would be even better) + noise contribution from CCS. This is feed through R104 to base of Q104. Q104 is BC550 with base spreading resistance of 150R@3mA and 145R@5mA. And there is another CCS, Q105.
In Fleapower regulator situation is not that bad. 10K and 3.3uF are forming LPF with Fc(-3dB) @ 4.82 Hz thus filtering voltage reference noise and shunting noise to GND (I would filter even lower, bellow 1 Hz). Shunting capacitor across 1K3 feedback resistor is decreasing AC gain (noise gain).
Anyway, I never stated that BiB is bad and Fleapower is SOTA regulator. I only gave Fleapower as start point for low 1/f noise regulator suitable for clocks.
Old 24th August 2011, 10:08 PM   #4217
Salas's Avatar
550R and 220uF is 1.32Hz, the cap is supply rail referenced. More than 220uF does not do much for total noise by running iterations up to 1000uF in noise sims, just slows the CCS regulation on the resistor. Maybe due to other noise sources prevailing. But for clocks 10Hz under noise, a 1000uF can be fitted no problem, there is space. They don't give noise density unfortunately for the Toshiba, just a 10Hz end dB value for 500R, 1K, 10k in the diagram I posted. Its almost equivalent to a K170 noise wise, which is very popular and maybe there is more data if we look around. I was just looking at components in each one and their possible noise generation for studying them. There is a 7812 CCS leg and output rail in the Flea to consider, BC547 BJT pass element final version in page two flea, same Rbb as BC550, as there is also a main CCS in the 1.1 etc. I don't have clocks and spectrum analyzers to fit both and see how the clocks pick up, if there is PSRR in clocks resisting some noise etc. I would make it out of curiosity since I have the parts and LT1028 even. Its just good learning to think by looking in specialized circuits, I never designed for clocks, or I especially recommended anything I made for digital. But its interesting discussion. I still give a fat order noise error and I estimate the BJT 1.1 3.3V at 100nV in the last 10Hz octave. And I am sure that a flea will multiply the basic 797 noise to a serious extent too.
Old 24th August 2011, 11:21 PM   #4218
Salas's Avatar
*This is the worse I could do simulating from 10Hz down to 0.1Hz so to approximate flicker output noise interest region for clocks. I threw in a 1mF filter cap on Vref for good measure. I am not a finite time sample integrator to FFT and average that for ever, but can it be 100-120nV p-p roughly?
Old 25th August 2011, 10:26 AM   #4219
stormsonic's Avatar
Simulations are my weak side
IMHO we should first find corner frequency for 1/f noise. Our helping point is approx. 3nV@10Hz. 1/f noise will go up 3dB per octave if we plot toward lower frequencies.
Old 25th August 2011, 03:22 PM   #4220
Salas's Avatar
I will ask the LT Spice experts if there is a directive that integrates density to RMS. Microcap 10 does it I think.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
