Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th May 2011, 11:22 PM   #3971
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by RCruz View Post
Maybe I am missing something but I can not figure R107 value 0.25r ?
1R
It's on the build guide on page 6.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 13th May 2011, 11:23 PM   #3972
Tea-Bag's Avatar
Here is the GB thread.
http://www.diyaudio.com/forums/group...ml#post2571174
Old 13th May 2011, 11:29 PM   #3973
RCruz is offline RCruz  Switzerland
RCruz's Avatar
On page 6 I see the schematics but without any values. I searched the pdf and got no values for R107.
Can it be ?
Old 13th May 2011, 11:46 PM   #3974
Tea-Bag's Avatar
It could be....
Here --- look for this. Maybe you should download again. Salas has updated.
R102,202,302 270R. R106,206,306 270R/27R. 270R for MOSFET output. 27R for BJT output. 1/4W
R108,208.308 47R 1/4W
R104,204,304,107,207,307 1R 1/4W
For R103,203,303 1/4W resistors & R105,205,305 Trimmer Bourns 3296Y style, read appendix 1
Old 14th May 2011, 05:01 PM   #3975
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi All,
When I connect 3 (5 volt) Sallas regs from one 12 volt Transformer I blow up a diode on the minus side, see attachment.
2 Sallas regs works fine but when I connect the third one to the DDDAC receiver board (only the 5 volt Sallas reg for the 74VHC4040M) it goose wrong.
Now I connect the 2 Sallas regs to 1 transformer everything is working fine.
I connect another 12 volt Transformer to the 5 volt Sallas reg B on the DDDAC receiver board and now are all 3 Sallas regs working.
Can someone tell me why are 3 Sallas regs NOT working with 1 Transformer?
I must connect 9 Sallas regs on 1 Transformer for the DDDAC also for the DAC towers.
Rudy
Edit: 12 volt 500 VA Transformer the right one is for the DAC.
It’s not what you know, but who you know “and where they are”
Old 14th May 2011, 05:12 PM   #3976
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Too low an impedance created and too hard a current pulse for a small diode maybe. Is it a big enough transformer also?
Old 14th May 2011, 05:42 PM   #3977
BMW850's Avatar
The diodes blow up are 1N4007 now I use 1N4004 and that works fine.
The Transformer I use on the picture are without diodes
I must connect 9 Sallas regs on 1 Transformer.
2off 8.4V 800mA (DAC Tower à 12xTDA1543)
3off 5V 80mA (Receiver board)
2off
3.5V 80mA (DAC Tower à 74VHC125N)
2off 3.3V 80mA (à VDD1 USB Receiver & DAC PCM2707PJT; 74HC08) (à VDD2 Tent XO Clock 12Mhz)
Here you have a PDF file: http://www.dddac.de/files/dddac1543mk2ver50.pdf
Rudy
Old 14th May 2011, 08:15 PM   #3978
back again
today i have replaced my transformer and experimented an 12 volts Pb acid accumalator with my Salas low shunt regulator V1.0 (5v) which powers up my M-Audio Transit usb soundcard.what i remarked is a more articulated sound.why there is audible difference between those two 12 volt supplies ? or should it be ?
thanks
ps : i like the sound with the accumulator the most
Old 14th May 2011, 10:55 PM   #3979
Salas's Avatar
Your Pb DC source is naturally smoother and non polluted than off wall rectified AC.
Old 14th May 2011, 11:30 PM   #3980
wondering what the difference would be in my jfet mm preamp?
i hope to get another two Pb accumulators(or to make an dc-dc converter(12v-30v)) and then i`ll give it a try.
Copyright ©1999-2013 diyAudio
