The simplistic Salas low voltage shunt regulator - Page 32 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd June 2009, 06:11 PM   #311
Banned
ikoflexer,
I answered your philosophical question. What exactly did you expect?
Old 2nd June 2009, 06:11 PM   #312
R5
Old 2nd June 2009, 06:16 PM   #313
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by ikoflexer
What are you trying to do with the 100R and 1k resistors? Which circuit are you talking about?
This is what he made, plus its negative in double mono. He ups the R5 so to avoid much heat on one MPSA05 due to having high enough DC in.
Old 2nd June 2009, 06:19 PM   #314
test shunt ok , see you later ,go over the amp..... now look like a dinosaur
Old 2nd June 2009, 06:36 PM   #315
Default OT
HI Salas , you thinks 10cm 0.5mm Ag is to small for signal ,driver->pw stage?
Old 2nd June 2009, 06:45 PM   #316
Salas's Avatar
No, its OK.
Old 2nd June 2009, 06:55 PM   #317
thanks!
Old 2nd June 2009, 07:09 PM   #318
iko is offline iko  Canada
iko's Avatar
Originally posted by nicoch46
hi iko ,43v
http://www.diyaudio.com/forums/showt...38#post1834938
Very neat! Keep us posted please.
Thanks salas!
Old 2nd June 2009, 08:15 PM   #319
iko's Avatar
Yes, I also see Q6 operating near the upper right limit of its SOA.
salas, why not do the R6 mod with the ring of mpsa05s (active load)?
Old 2nd June 2009, 08:21 PM   #320
Salas's Avatar
If the BC550 is sinked it can work with an active load safely even at that voltage. Ring of two again is a solution, but haven't tested it and don't know if will oscillate.
Copyright 1999-2017 diyAudio
