#301 |
Thanh,
I sent mail to "bin teh" - do you have a new one?
... jh |
#302 |
Banned
What is bin-teh?
#303 |
Sorry, can you email me? ...
... jh |
#304 |
I think it would be good at this point to recall where things are coming from and thus give credit where credit is due. Can anyone recognize this topology?
![]() If you don't, then you haven't looked carefully at salas' regulator. This design is due to Are Waagbo, who published an article named "Shunt or Not" in the Feb 2008 issue of AudioXpress (US print magazine) pp. 30-37. Here's a link to the actual article, which is a very good read: http://www.borbelyaudio.com/pics/waagbo2863.pdf Notice the article is hosted by Erno Borbely's website. This is no coincidence, as Mr. Waagbo and Mr. Borbely are friends. In fact Mr Borbely says this in an interview: "My friend Are Waagbo used a combination of a series current-source feeding into a parallel shunt, and that is probably the very best you can do for regulated supplies. ... What I find quite important in supplies is to use reservoir caps with the lowest ESR practicable, and use lots of it. I believe in very stiff raw supplies. That makes sure that the raw voltage going into the regulator is as smooth as possible. And, by the way, Walt and you have also done a lot of good work on regulators!" The interviewer being Jan Didden, the last sentence refers to him. In fact I regret that Jan Didden has not chipped in at all in this thread; his experience with regulators is immense and I'm sure he could have contributed some awesome advice. Anyway, the entire interview can be found here: http://]http://www.borbelyaudio.com/...nalsMMM508.pdf One last point. Looking at Erno Borbely's All-FET low-noise super shunt regulator one can see perhaps what inspired Are Waagbo. ![]() Hey, Mr. Lumba, do you recognize the diff amp? I have great respect for Erno Borbely's work. If anything, he's got proven designs and if I really wanted a diff amp, I would have inspired myself from him. So I have been aware of these particular designs for some time, and not only. I have implemented a few of them, including Are Waagbo's, Sultzer, Jung, and I can't recall how many variations on those. Implemented as real circuits. I've also ran them all through the simulator and, Lumba, I will not give up ltspice just because you think it's garbage. You're certainly entitled to your opinion, but AFAIK your opinion cannot be very informed, or you wouldn't have said what you said.blablabla |
#305 | |
Banned
ikoflexer,
Fortunately, there`s no need to simulate straightforward circuits, like shunt regulators. |
#306 | |
As far as I'm concerned, everyone should use whatever they like. Thanks! |
#307 |
I love Erno
![]() Uff ! search 100r , found 1k and 100r , put on the left and 1k on the rigth mod the shunt , no works! led off , what resistor I have put in ?!!! I hope later tonight the amp is done
#308 | |
#309 |
#310 |
diyAudio Chief Moderator
Nicoch, if you used 100R R6 then your respective BC550 is dead. Change it. If you used R5 1k, then the current through the LEDs is very low. Change it to 100R.
