The simplistic Salas low voltage shunt regulator
Old 23rd May 2010, 07:03 PM   #2521
pidesd is offline pidesd  Canada
pidesd's Avatar
i m no expert, but is it not recommended to add holes for to-220 mosfet too?
Old 24th May 2010, 12:05 PM   #2522
tubo is offline tubo  Philippines
Originally Posted by Salas View Post
Try this one. I don't like to go so low in Voltage output, near the Mosfet Vgs margins, but this one looks like working alright on the simulator. Try it, I haven't tried for 5V before. Its inexpensive to make p2p and see if it will do well for you.
hey guys,
will the regulator be able to power a squeezebox touch which has a 5v 3amp requirement? what do i need to replace on the scheme to output 3amp?thanks
Old 24th May 2010, 12:15 PM   #2523
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
V1.0 has done 3A at 13V for a T-Amp. The dissipation at 5V is almost 1/3rd than that, so I guess its possible. Its only Rset that needs go low value and you need substantial sinking. Since that post many used it at 5V for digital. DACEND, DVBPROJECT's 1541 REF, Merlin El Mago on Buffallo remote sensed, etc.
Old 24th May 2010, 12:58 PM   #2524
if i understand it correctly i just need adequate sinking ? i believe 6 ohm for the rset with a 12v supply. and 10 ohm for rset with a 15v supply.
Old 24th May 2010, 01:09 PM   #2525
Salas's Avatar
Is it the 3LED CCS? Shoot for Iset=2V/Rset roughly.
Old 24th May 2010, 03:06 PM   #2526
massimo is offline massimo  Italy
Originally Posted by THKL View Post
@Massimo: would you advise to use a groundplane "net" (how is that kind of groundplane called, btw?) or leave the ground trace alone?
I thought the groundplane could add some screening, but I'm no analogue wizard...
I don't think GP is necessary in analog pcbs, and, as pointed out by Salas, a solid GP is like adding a big cap. If you want it, use a grid or net, but better without IMO.
Verify hole size: if you vary hole size for each components, the pcb price goes up. Consider that through hole plaiting reduces the actual size by 0.1 -0.15 mm. Small bjt/fet pads are still too small for me. Easy to destroy them if you have to desolder a component.
Move 33 pf cap to the left (on top of 1k resistor) in order to reduce track lenght. Its pitch can be 5 mm or smaller if you use a good ceramic component.
Old 24th May 2010, 04:45 PM   #2527
THKL is offline THKL  Germany
Thanks for all the feedback.
I designed a new PCB for the LED-reference BJT-cascode and tried to incorporate all the feedback.
The small transistor pads have been increased (they now only have 0.3mm space between them - I don't think that it'll be a good idea to further reduce it - any comments, maximo?)
Due to popular request I also added TO220 holes to the PCB layout.
The new design looks cleaner IMHO.
Since the new design does not require IDSS sorting, can go for higher input voltages and performance is the same as the older version, this new design will become the standard design I will be working on.
@Salas:
1.) Somewhere in the thread it was mentioned that LED-reference could be used in the remote sensing and adjustment part, too. Does that improve overall quality? (There seems to be enough space left in the new design so that I could even add in that option with a "daughterboard".)
2.) I understood correctly that the performance of the LED-reference version is at least the same as the one with 2SK170/2N2559, did I?
3.) At the moment the circiut contains BC560B and BC560C. Can't one model be used for all without compromising performance?
Old 24th May 2010, 04:50 PM   #2528
If I remeber right, Salas advised on using a Silver Mica 33p and I took the footprint from the datasheet. I don't know about performance of different capacitors there, but I'm eager to learn and changing the pitch is not a big deal...
Old 24th May 2010, 04:59 PM   #2529
Salas's Avatar
3.Yes, use 550B-560B for those CCS TO-92s, so some will not stick out for hfe too much. Had no problems with mixing B or C, or all being C, but the B grade is more conservative around 300 hfe.
2. Yes, equivalent. BJT or FET cascode same PSRR.
1. LEDs are for fixed reference on a daughter board if you fancy. In that case you should have to jumper the source to ground of the trimmer controlled JFET, because the LEDS are going to need stronger current to be happy. They are stiff, will not come up thermally anymore than +/-0.4V, the resistor will slide with the small Jfet current coming to thermal final -but stay then-. Also less impedance. A bit different subjectively than a resistor Norton ref. Semis are active things. Much of a hassle for 24V, not recommended there since you will also lose noise performance gradually with number, but nice in the 5V.
P.S. Don't know if TO-220 will work equally well given the extra length to gate stoppers in your last iteration. But they can always get soldered directly to legs and just leave their other leg lengthier to is pad.
Old 24th May 2010, 05:00 PM   #2530
Salas's Avatar
C0G/NP0 recommended equally.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
