#2021 | |
R1 & R2 can be 0,25W? This schematic is for use with the PS or with battery, I suppose is for running with the PS, right? Last edited by merlin el mago; 6th March 2010 at 04:36 PM. Reason: Add |
#2022 | |
Other than adjustablity, is there an advantage of using resistors at R6 vs a zener? Fairchild has 1nxxx zeners in higher voltages. Ken L |
#2023 |
diyAudio Chief Moderator
Merlin, that photo without words, verifies that +V battery at Vin+ lights them up so they are correctly oriented? May we
#2024 |
#2025 |
Ok I post the pic to show you. I do as the Jig to match the LEDs: 1Kohms in series between the battery + & the LEDs to be matched.
#2026 |
#2027 |
Hello all,
I want to build a +/- 15V power supply for a phono pre-amp stage, and after looking around about the different projects in the forum, I'm inclined to build the circuit you're discussing here. The intend to install the power supply (including transformer and rectification) in the same box as the pre-amp, which by the way, is the balanced outpur version of the RIAA phono pre-amp stage from Douglas Self. As a starting point I would like if anyone could please indicate me which version (post?) of the circuit should I start looking at? Thanks in advance, |
#2028 |
Sorry, I missed that question. Yes, R1 and R2 would work if 1/4W. Yes, the schematic would be for PS, not battery. I'm going to go out run some errands soon, so if you have results soon I might be able to comment, otherwise, later. Good luck!
#2029 | |
#2030 |
Hurra, the LEDs are lit
the problem was that I forgot the connection between LED's/R2 & C1/Q6![]() Now I have 55V after the reg. but I need 45V & the trimmer pot only increase or decrease 0,2V? |
| Page generated in 0.16266 seconds (70.06% PHP - 29.94% MySQL) with 11 queries |
