#1831 |
#1832 |
The bigger trannies (300VA) have lower Rdc as their primaries are wound with thicker wire. The least I've measured was 4 ohm. The danger lays in the smallish trannies which can have as much as 100 ohms. Left school too long ago to give you the exact time it takes to discharge 10uF over 100 ohm
jaap |
#1833 |
That size cap, or any in x.00uf on AC mains is dangerous.
I've used them to break in caps and hold one helluva charge and take same when energized. If you energize it at the peak of the cycle it can explode. Lots of info on this. DC does not have a wave form...it's a flat line on a scope. You also, playing with phasing. I know what JC is doing and it was a product that Bob Crump sold. I suggest NOT doing so. I sent you links for doing AC filtering the proper and safe way. They work great. |
#1834 |
Thank you Bill for the kind words on my SW tutorial: it's always nice to know that my work helped someone.
#1835 | |
This led me to investigate different configurations in my power amps - C, CRC, CLRC, LRC. Originally I had C = 3 x 10,000uF per rail per channel. These capacitors have inductance of 16nH and ESR of 0.015R at 20kHz. I tried CLRC 10,000uF - 220uH (0.05R) + 0.1R - 2 x 10,000uF. From LTSpice modelling, I must insert a resistor 0.1R so that it won't have a peak at around 80Hz. While I found the higher frequencies were definitely cleaner, the sound became a bit unnatural to me, perhaps due to increased impedance. I then tried more Spice modelling, and found that LRC 220uH (0.05R) + 0.1R - 3 x 10,000uF would give another a few dB ripple rejection. I tried it. The sound was subjectively the best comparing to C or CLRC. Then I wired up the 4 rails differently and measured them with my scope. The scope confirmed my subjective impression, that LRC is better than CLRC. Note that the total 0.15R resistance in series with the rail is higher than the impedance provided by the capacitors, in the case of CLRC, it was 0.015/2=0.075R, and in the case of LRC, it was 0.015/3=0.05R. So I am going to redo my preamp level raw supply before the CCS-shunt regulator to change it from CLRC to LRC and see if I can find any subjective improvements. The above may only work with soft recovery rectifying diodes with which no snubbing high Q film capacitors are used, or possible severe ringing can occur due to the interaction of the C and the L, unless you pack sufficient resistance for damping, but in which case, the increased impedance may do more harm than good. My hypothesis is this: Filtering can only be done with either capacitor or inductor, (along with resistors), or both. Electrolytic capacitors are OK at lower frequencies but not higher frequencies. Bypassing electrolytic capacitors with ceramic or film caps (all of them are of high Q) can easily cause ringing. Inductors are naturally good at higher frequencies (but watch out for parasitic capacitance, as Salas reminded me, so the proper inductors need to be selected). The idea is to use electrolytic capacitors for lower frequency filtering, and inductors for higher frequency filtering. In this case, only a small RF choke is needed, with the significant advantage of much lower impedance (comparing to a large L or R), minimal voltage drop, minimal heat dissipation, minimized RF rediation, minimal space required, and lower costs. My hypothesis is in sharp contrast to conventional LRC or CLRC in which the large L is to filter ripples down to the audioband or even the mains frequencies. The only thing I am not sure is this: there may be a significant amount of DC which may saturate the inductor core making the inductor ineffective. I don't know if this can be a case so am seeking experts' advice on this. |
#1836 |
#1837 |
diyAudio Chief Moderator
Use garden variety red or green 1.8-2.1Vf LEDS, best quality capacitors across Vrefs and lose the 0.1uF bypasses, its a hit or miss. Stealth II diodes for the rect bridges or MUR 120, more compact for size and easier on budget.
#1838 |
It can be. If there is DC current you need a properly rated core in any inductor. In case of using small values to dump RF, small air core coils are feasible though.
#1839 |
I have not tried a lot of diodes but only a few.
The cheapy shottky diodes 1n5822 (and its series) actually sound pretty good, and sustantially better than the normal 600V 35A bridge, although I have heard comments that the 1n58XX series do not sound as good as other shottky diodes, such as D10XXXXX, etc. I measured with my scope and found the 600V 35A bridge (in both my preamp and power amps) produced horrific switching noises, if I show you the magnified spectrum, you would believe these diodes are dedicated noise generators. Salas then recommend trying the Fairchild Steath. I tried them. They sounded a bit cleaner than the 1n5822. I measured the rectified wave forms, the result was much much better than the 600V 35A bridges. Actually, I am spending this week replacing the 600V 35A bridges with the Steath on my 3 pairs of monoblocks (and other upgrades on them as well). I will possibly finish them tomorrow and will measure them again. It will be interesting to see if they make any improvements on sound, as these power amps are very well designed and should have a theoretical 115dB PSSR across the entire audio bandwidth. In theory, these diodes should make no difference to the sound of my amps. |
#1840 | |
I thought of air core inductors for loudspeakers. But since they have quite a bit of windings I suspect that the parasitic inductance is on the high side, making the inductor less inductive at higher frequencies. I am trying these: http://www.bourns.com/data/global/pd...120_series.pdf The datasheet says that until the current reaches 5.21A the inductance of the 220uH will lose half. To me that is pretty good, as my class AB amps would never draw that amount of current. The question is, with the inductor immediately after the bridge rectifier, what is regarded as DC? Would the rectified wave form be considered consisting of any DC component? |
| Page generated in 0.13353 seconds (61.11% PHP - 38.89% MySQL) with 11 queries |
