The simplistic Salas low voltage shunt regulator
Old 1st February 2010, 07:13 PM   #1791
wheezer is offline wheezer  United States
Would it be possible to get the schematic of a working version good for around 20Vin and just the CCS portion?
Thanks,
W
Old 1st February 2010, 07:22 PM   #1792
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What exactly? Positive side V1.0? What current?
Old 1st February 2010, 09:32 PM   #1793
Ooooops...me bad.
Positive rail and about 400mA.
Thanks,
W
Old 1st February 2010, 09:58 PM   #1794
Salas's Avatar
9 to 13Vout it can be good for, with 20Vin. Is that OK? Also is the load less than the 400mA CCS you specified?
Old 1st February 2010, 10:02 PM   #1795
Perfect
No.
Thanks,
W
Old 2nd February 2010, 01:44 AM   #1796
Salas's Avatar
Use a LEDS CCS V1.0 schematic. You just need to use low R1 for a current at least +20% of your (substantial) 400mA load. Depending on your LED Vf you must have 5W loudspeaker crossover style sandcast resistors maybe 3R3 or 4R3. The voltage across them divided by their value will give you the actual running current. Use 3K3 trimmer in the Vref, adequate sinking, and you will be ready.
Old 2nd February 2010, 05:21 PM   #1797
Salas,
Thank you very much for the detail and specifics for my application.
It took a bit of time to find this; I assume this is V1.0:
Thank You,
W
Old 2nd February 2010, 06:11 PM   #1798
Salas's Avatar
As in your pdf is the Leds controlled CCS which is more helpful with the resistor values for the current range you asked for. The trimmer goes where the Zener is. Follow post #1796 above for your needs.
Old 3rd February 2010, 12:55 PM   #1799
fastvideo is offline fastvideo  Canada
Salas,
Since IRFP240 is in back order, what is the best direct replacement for IRFP240 and IRFP9240?
Thank you.
Old 3rd February 2010, 01:53 PM   #1800
Salas's Avatar
IRFP140 and IRFP9140
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
