#1531 |
Ok! thank Massimo!
#1532 |
Hi Salas
I bypassed the 10r R1 with a 47r and am now reading 250mA between the smoothing cap and the shunt... (I am testing the shunt without any load). Is this the correct way to measure shunt´s working current ? Regards Ricardo |
#1533 |
@RCruz
R1=10 Ohm, bypassed with 47 Ohm. Total resistance = 8.24 Ohm Measure voltage drop across this paralleled resistor. Divide voltage with resistance to get current. For 250mA voltage drop should be approx. 2.06V Parallel resistance Calculator Last edited by stormsonic; 21st November 2009 at 01:11 PM. Reason: Link added |
#1534 |
My measurements are 8.39r on R1, 1.99Vdrop on R1 so I calculated 0.237A... but measuring the current flow in the shunt input I get 0.25A.....All this without loading.
How can I explain the current diferences ? Ricardo Last edited by RCruz; 21st November 2009 at 03:55 PM. |
#1535 |
diyAudio Chief Moderator
Dvm?
#1536 |
Probably
![]() I settled for 10r//27r Vdrop R1 = 1.964v Current should be 265mA. These are the measurements on the 4wire shunt I am now going to try ! It gets hot.... 76ºC on the power mosfet but I have good sinks. Ricardo |
#1538 |
#1540 |
I always liked those green perfboards you use. I never seen them in stores here. You know, the sinks are rather small for the current. The IRFPs are dogs though.
| Page generated in 0.13133 seconds (52.62% PHP - 47.38% MySQL) with 11 queries |
