#1511 |
Quanghao, how can you produce professional looking pcbs quicker than we can even think about?
Do you work in a pcb factory? Can we send you some drawings and have them produced as samples? It goes without saying we pay for them and cover shipping costs Last edited by massimo; 17th November 2009 at 11:17 AM. |
#1512 |
[QUOTE=massimo;1983637]Quanghao, how can you produce professional looking pcbs quicker than we can even think about?
Do you work in a pcb factory? No! Im design, I'm just a diy, I do Board for me and for my friend use. Can we send you some drawings and have them produced as samples? Ok! I can help you! if you sent me you file, I think, It is standard after a week production is completed. You can sent for me by e-mail: mythuat818 @ gmail . com Or quanghao168 @ yahoo . com . vn Thank |
#1513 |
#1514 |
#1515 |
diyAudio Chief Moderator
#1518 |
If you got the sinking, the stronger you run it tends to become lower output impedance. If you have applied the force/sense wires already it may be even an audible bit in your low PSRR SE phono application.
#1519 |
Salas
Instead of searching for (unobtainablum) parts like 9,4 or 9,5 2w resistors, I was wondering if I could change the leds. Can I use low current leds like : ROHM|SLR-342YC3F|LED, 3.1MM, YELLOW | Farnell Portugal Does the current spec matter ? Can I determine Vdrop from the led spec ? Regards Ricardo |
#1520 | |
Here are some models. I don't know how good they are. .MODEL LED_RED D (IS=93.2P RS=42M N=3.73 BV=4 IBV=10U CJO=2.97P VJ=.75 M=.333 TT=4.32U type=LED) .MODEL LED D (IS=93.1P RS=42M N=4.61 BV=4 IBV=10U CJO=2.97P VJ=.75 M=.333 TT=4.32U type=LED) .MODEL LED_Blue D (IS=93.1P RS=42M N=7.47 BV=5 IBV=30U CJO=2.97P VJ=.75 M=.333 TT=4.32U type=LED) - keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
| Page generated in 0.10788 seconds (66.35% PHP - 33.65% MySQL) with 11 queries |
