#1021 |
Hi everyone, not much of listening the last week as I was experimenting with xover points and level matching for my FR/supertweeter speaker system. I had also changed the smoothing caps to 2 x 10,000uF KMGs and letting them to run in.
#1022 |
Yes, when I compare regulators this is one of the tests I do. It's almost magical to see that wiggly trace across the screen.
What do you mean by noise output? I should add, at the end of the day it is still your own subjective impression of the sound that will matter to you. So best will be to listen to all of the alternatives that tickle your imagination, and decide what you like. Regarding the output impedance of simulated models, I'm not as naive as to think that we'll see any such results in reality. Hopefully someone with good measuring equipment will do a shoot out of all these regulators one day. |
#1023 |
Banned
Iko, I meant the added or generated noise, I guess. Batteries have been shown to produce noise associated with generating current so I guess this would be what I'm wondering about but I'm thinking that it's not going to be too easy, so as you say listening is the final arbiter.
#1024 | |
In no way I'm going to argue with professional results.
It's good that you're a skeptic, you'll learn a lot this way. Edit: btw, the only reason why I ever do these tests is to satisfy my own curiousity. I don't claim my tests are worth a penny, and definitely I'm not trying to convince anyone of anything. Last edited by ikoflexer; 21st August 2009 at 03:59 AM. |
#1025 |
diyAudio Chief Moderator
Jkeny:
Will not the batteries add up impedance since you have to chain several of them in series to get up to about 13V for the T amp? |
#1026 |
Banned
Yes, Salas, you're correct - 4 in series (13.2) will add the impedances - 16 to 32 mOhm which could be detrimental? (BTW, these are the batteries of choice being used in the electric vehicles, GM's Volt, etc. - just thought this might be interesting info)
Iko, it's not that I'm sceptical - I believe the great results attested to here - I'm just interested how it will fair against a great battery as it's ultimate test. As Salas said, it would be impressive if it matches or surpasses some of these better (expensive) ones - Soundcheck, I believe, runs all his kit on NorthStar NSB 90 batteries internal R of 2mohm. As I said, don't mistake my questions as anti-regulators; I'm a user of John Swenson's high voltage series regulators based on Gary Pimm's self biasing CCS and believe it offers excellent sonics. |
#1027 |
I am actually much interested in comparisons with everything and subjective results. What is best goes, that is my motto. Ease of making, cost, reliability and functionality included in the mix. A member is using HV Swenson on tubes now that you mentioned, and he is experimenting with my HV simplistic as well, maybe soon he will tell us if there is any subjective gain or not comparing it.
#1028 |
Banned
One point favouring your reg is that it scales; the Swenson is only for high voltages & doesn't scale down. A sonic comparison between them would be excellent!
#1029 |
Not directly equivalent to what you gonna make for your T-Amp, its the ring of two, resistor Vref ultra simple HV.
The simplistic LV's scaled from 10V on DC B1 to 250V on Iko's HV high bandwidth version, and from 70mA to 2.5A by now on actual builds. |
#1030 | |||
Banned
| Page generated in 0.13196 seconds (63.71% PHP - 36.29% MySQL) with 11 queries |
