Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th May 2009, 05:57 PM   #1
Default Low noise Regulated +-12v supply?
Hello.
Im in need of a regulated supply for ICE-Power Class D amplifier modules.
Specfications are that it needs to be 12V Positiv and Negative.
They need to be able to hold a current of about 1A to be safe and be as low noise as possible.
So the question really is. What is todays best voltage regulator in terms of noise that can handle the terms above?
//Gregor
Old 6th May 2009, 05:27 AM   #2
Send a message via AIM to DigitalJunkie
The venerable 7812/7912 or LM317/LM337's should be okay.
Just be sure to heatsink them well.
Old 6th May 2009, 06:30 AM   #3
mjf is offline mjf  Austria
hello.
how many modules do you want to run with the power supply -(power consumption)?
annother suggestion:
that kind of discrete regulators n. pass uses are low noise . have a look at the zen amp regulators and at the aleph p 1.7 preamp reg. or so.................
greetings..................
Old 6th May 2009, 02:03 PM   #4
I am going to run 2 modules. Acording to the dataseet the powerconsumtion is about 250mA per module. So im thinking of just safing and going for 1A.
I earlier today received some regulators from Linear, LT1086 fixed at 12V. I was using the 7812/7912 before but the noise what pretty pronounced when i turned the amplifier on and had nothing connected to it. The LT1086 made the amplifier a lot quieter. So im guessing that this regulator is quieter than the 7XXX i was using.
The only strange thing now is that when i turn my preamp on. The noise is louder than it was before.
But in contrast to that i do feel that the sound has become a lot richer in detailt. Might this possible? Or am i just imagining it?
Im guessing the lower noise from the regulator made the ICE-power module more sensitive on inputs
Old 6th May 2009, 03:44 PM   #5
hello.
a clean power supply is essential for good sound.............or the noise floor will hide the fine details of the music ........
3 Pin regulated supply VS zener based supply KevinLee Solid State 3 15th September 2008 02:40 PM
57 V regulated low noise Luis P. Solid State 8 7th February 2006 05:07 PM
regulated supply +- 28V -20A sss Power Supplies 8 14th June 2005 07:30 AM
Quick help needed! LOTs of noise in BBMCCCS loaded /0A2 regulated preamp! stigla Tubes / Valves 17 12th May 2005 12:02 PM
regulated 5V DC supply Tomatito Tubes / Valves 50 4th February 2003 08:33 PM
Page generated in 0.08308 seconds (70.76% PHP - 29.24% MySQL) with 10 queries
