#2 |
That looks like a beast of an SMPS! I'm not sure of your snubber values, but that thing looks setup for serious power!
You can call me Mad Professor, building crazy experiments in my Electronics Workshop |
#3 |
There is a mistake in the design. 6A input will not be enough to get 200A output at the input and output voltages.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#4 |
thanks for help !
I will change ! The problem is RC SNUBBER value! |
#5 |
the values of RC snubber components are directly related to parasitics in your transformer and layout.
Measure the ringing frequency at mosfets turn-on/off, then choose the resistor snubber value equal to the characteristic impedance given by measured leakage inductance: R=2*pi()*Fringing*Lleakage. The capacitor value comes immediately: C=1/(2*pi()*Fringing*R). |
#6 |
Multumesc!
thanks for help Florin ! |
#7 |
Any pictures of this beast? Trafo, did you build it or what?
#8 |
: Hello Luca. There is no beast...yet. Right now it is in the design / testing stage and everything looks very ugly. I didn't have time to draw a pcb so everything is connected with wires at this point. I managed to acheive something good at 30kHz
I increased the frequency to 50kHz and I want to re-calculate the correct values 32Khz ringing 12,82Mhz ![]() 32Khz whit snubber ![]() 32Khz in Power, primar I=3A, U=90v ![]() Waveform at 50khz whit snubber ![]() ![]() All tests were made at 30v and 100v |
#9 |
more dead time on second, I think it was 32kHz picture. slope should go all the way up..
#10 |
| 13vdc-200a Smps Hard Testing | CHACALPOWERS | Power Supplies | 8 | 1st August 2008 08:41 AM |
| AER FS2B and Fostex 200A comments | InclinedPlane | Full Range | 8 | 10th April 2007 12:03 AM |
| Page generated in 0.10886 seconds (73.04% PHP - 26.96% MySQL) with 10 queries |
