Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd May 2009, 03:34 PM   #21
Originally posted by Steerpike
I have only a cheap car battery charger (transformer - rectifier - thermal cutout); even a 'dead' battery always manages to get about 2 to 4 amps from it, but a dead battery never fully charges - even after several days. Hydrometer testing always shows 5 fully charged cells and one flat cell.
I had several batteries like that, where one cell is lower than the rest. After long, and slow overcharges, it eventually equals them out.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
Old 2nd May 2009, 07:02 PM   #22
Steerpike's Avatar
Oh really? How long is 'eventually'? I gave up after about 72 hours, but maybe I should have left it longer. This is ALWAYS the reason I have to buy a car new battery - was that a waste and I could have restored the battery by charging long enough?
I keep meaning to build a low current charger (les than an amp) that I can leave on 24/7/365.
Old 2nd May 2009, 09:32 PM   #23
star882 is offline star882  United States
star882's Avatar
Just take an unregulated 12v wall wart and connect it to the battery.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 4th May 2009, 09:16 PM   #24
theAnonymous1's Avatar
I'm in the process of trying this out on a completely dead battery that was in a car I've had sitting for a long time. I tried charging it with my car charger but it just keeps cycling on/off.
I was trying to get a 60w bulb hooked up to the circuit, but getting a wire attached to the steel base of the bulb proved to be an excesses in futility. I ended up using a 7.5uF motor-run cap instead.
When I first plugged it in the voltage was around ~17V and has slowly dropped to ~12.4V (and still dropping). Current draw measures around 270mA.
I will post back with my final results later.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 5th May 2009, 12:48 PM   #25
Success!
I left the "desulfator" on the battery for around 5 hours at which point the voltage was ~12V. I felt this was high enough for my automatic charger to take over so I set it at 6A and left it over-night.
After the charger completed it's charge cycle the voltage was ~13V with the charger in trickle charge mode. I then connected the battery to a transformer out of a an old linear regulated 12V 10A supply (with a rectifier of course). After just a few minutes the voltage was at ~15.5V and the electrolyte was boiling rapidly. I think I need to put some resistance in series, the transformer is capable of too much current.
Anyway, it seems to have worked on this >5 year old battery. I will probably do a slow discharge and charge it back up again before putting it back in the car.
Old 5th May 2009, 05:13 PM   #26
jkeny is offline jkeny  Ireland
Banned
moderators, why am I getting no email notifications from this thread even though it says I'm subscribed?
Old 7th May 2009, 02:57 PM   #27
Originally posted by theAnonymous1
Success!
Sweet! Glad to see you got that old battery to take a charge.
7.5uf, pretty sweet. Is there any heating of the capacitor, or does the circuit remain cool?
Old 7th May 2009, 06:02 PM   #28
The cap and rectifier remained completely cool.
I'm not too good at this stuff, but doesn't the cap form a first order high-pass filter? If so, according to the current draw I measured (~270mA), shouldn't the cap be dissipating around ~32W? It didn't feel like it was dissipating any power at all.
I would like to find another battery and try this again with a slightly larger capacitor.
EDIT: Oops, there was a flaw in my above thinking. I didn't measure the current draw on the AC side, I measured it on the DC side when the voltage was under 12V. That would make it more like 3W of dissipated power in the cap, correct?
Old 7th May 2009, 06:18 PM   #29
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
cap be dissipating, well cap don't dissapate anything [not 100% true], it blocks, slows, however you want it... it is not like resistor
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 7th May 2009, 06:41 PM   #30
Oh, I thought it acted like a resistor below Fc. So actually, if it does work as a high pass filter, the higher the internal resistance of the battery (due to sulfation) the more current flow there is in both the battery and the capacitor.
I have no clue what I'm saying.
Amp6-BASIC kit and 12v lead battery mallerfar Class D 0 25th June 2009 05:47 PM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
keeping a sealed lead acid battery on its side? michelevit Chip Amps 3 12th June 2006 06:42 PM
battery charger for lead acid abs_hmo Car Audio 0 8th December 2005 06:44 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.12186 seconds (80.21% PHP - 19.79% MySQL) with 11 queries
