Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th April 2009, 08:42 AM   #1
binspaul's Avatar
Send a message via Skype™ to binspaul
Question 15mA 120V AC Power supply dessign
Does anybody has a PCB schematic for the following power supply:
* Input voltage: 220V AC @ 50Hz
* Output voltage: 24/48/110V AC @ 50Hz.
* Output rating: 10mA to 20mA.
Are there any transformers available in this specification ?
Bins.
Old 1st May 2009, 08:05 AM   #2
Hi, there should be suitable transformers readily available meeting your specs. Just check the catalogs!
-Juha
Old 8th May 2009, 12:13 PM   #3
binspaul's Avatar
I was able to find some transformers in the required voltage ratings from the site: http://www.futureelectronics.com. But, the current ratings is around 50mA to 100mA, which is mush bigger than my required value. Is there any way to reduce the current to the required level of 10mA to 20mA ?
Thanks in advance,
Bins.
Old 8th May 2009, 08:53 PM   #4
It's not bad at all to have a little extra current capability. You are building a voltage source now, and the load current will be determined by the load, not the source. So having a transformer with certain current value doesn't mean that the transformer will be sourcing that amount of current all the time!
You'll do fine with the transformer you found.
-Juha
Old 11th May 2009, 05:47 AM   #5
binspaul's Avatar
Hi Bootstrapper,
As per your reply, I am planning to go for the transformer with the following ratings:
* Primary Voltage: 115V
* Secondary Voltage: 24 +/- 10V
* Secondary Current: 41mA
* Rated Power: 1VA
I have attached the motor specifications file below. It will be really helpful if you can advice on my decision. Do I need to choose a much higher value transformer available (like 63mA or more) ?
Thanks & regards,
Bins.
1500VA power transformers 120V:120V RyanW Swap Meet 4 17th February 2009 08:31 PM
DIY 120V Power Supply ak_47_boy Power Supplies 13 21st January 2007 09:22 PM
my SY CCS is only giving me 15mA Shoog Tubes / Valves 17 6th March 2006 06:43 PM
FS: 120V, 8.3A Toroid Power Transformer TheDamonator Swap Meet 1 14th October 2003 04:05 AM
Using 120V transformers with 240V supply Peter Daniel Solid State 12 21st January 2003 12:32 AM
Page generated in 0.06410 seconds (84.03% PHP - 15.97% MySQL) with 11 queries
