So my chipamp is using this PSU:
http://chipamp.com/images/ps-rev3-sch.gif This has a +30v and a -30v rail. Along with my chipamp, I have some preamp type stuff inside the amplifier case. All these circuits want +/- 15v power. What's the easiest way to get a +/- 15v supply along with the +/-30v supply from this PSU? Thanks! |
#2 |
if you have this dual 30 V supply already, you might consider using simple linear regulators to drop the voltage to dual 15 V. Check LM7815 for example. However, if you require more than 1 A current per 15 V rail, there are other linear regs that can provide more amps. There should be suitable simple circuits given on the LM7815 datasheet for you to build, but pay attention to proper heatsinking and protection circuitry! There will be quite a large voltage across the regulator (roughly 15 volts in this case) and when you take the full 1 A out of it, you'll waste 15 V * 1 A = 15 W power! So decent heatsink is a must, fan not necessarily needed. Have fun!
-Juha |
#3 |
Right now I'm doing this with little TO-220 LM317 regulators. Needless to say they're ridiculously hot to begin with and only one of them is minimally heatsinked. They seem to work fine, however. Should I expect them to have a decreased lifespan or any other problems?
Thanks! |
#4 | |
#5 |
i use transistors to increase current of a linear regulator , use 1 mje3055 and mje2955 for constant 2 ampere output .
besides using using 317 or 7815 to drop out the voltage will make them very hot so use a current limiting resistor and transistor to increase the current . it will solve the problem |
#6 |
Umm, a weird question. Are these circuits electrically isolated from the amplifier circuit? If so you could split the 30V to +-15 (30V=15V and ground = -15V)
#7 |
Hm good idea horizonrays.
Is the heatsink on the left adequately sized? Should I give them both larger ones? I guess I could. These circuits are used to run the opamps in the pre, primarily, as well as for some switching relays. |
| Research on tubes and circuits simple circuits | Cazcotty | Tubes / Valves | 6 | 16th June 2006 12:50 PM |
| 85 powersupply circuits 58 charge circuits | gev | Power Supplies | 0 | 31st July 2005 11:27 AM |
| PSU sharing grounds | neutron7 | Parts | 2 | 5th March 2005 12:23 AM |
| Best gainclone circuits summary | vossie | Chip Amps | 8 | 27th August 2004 01:46 PM |
| Sharing DAC outputs | Prune | Digital Source | 0 | 22nd January 2004 10:40 AM |
| Page generated in 0.09503 seconds (76.60% PHP - 23.40% MySQL) with 11 queries |
