Hello all,
I have a PS question - I have used a Choke input design to better reduce ripple and reduce the B+ of a tube amp before and it worked perfectly. I am looking at another Choke input application where I can use a Dual secondary tranny (40 - 0 40 - 0) with a choke input to get around +/-35 VDC rails (VDC =.9 x VAC) for a class A Zen amp. I found an SAE EMI filter that measures 12mh (with my LC meter), .1 ohm series resistance input to output. Also rated for 6A each side. Looks to be a perfect drop in solution to put after the FWB rectifier and a Cap multiplier. The diagram is shown below. The diagram shows the small caps across the rails, and two 7 mh coils on both sides with a 270k ohm resistor in center. Anyway, any reason to think this wont work as a choke input filter?? I see these al l the time on flea bay and wonder if instead of finding a 2.5mh inductor, just use one of these jobbies...
Pillage Before You Burn. |
#2 |
calculate the maximum and minimum currents that the 7mH can supply.
regards Andrew T. |
#3 | |
Martin Rupp |
| choke input power supply filter | audionut | Pass Labs | 49 | 29th January 2012 06:38 PM |
| Choke input filter LF noise | astouffer | Tubes / Valves | 27 | 6th June 2011 11:51 PM |
| Choke Input Filter. | G | Tubes / Valves | 8 | 11th February 2008 09:57 PM |
| Choke rating for choke input duty | cbutterworth | Tubes / Valves | 14 | 9th November 2007 05:43 PM |
| SOZ Choke input filter? | gnomus | Pass Labs | 48 | 14th May 2004 07:41 PM |
| Page generated in 0.07040 seconds (70.91% PHP - 29.09% MySQL) with 10 queries |
