Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th April 2009, 08:06 PM   #1
jackinnj's Avatar
Default Temperature compensated MAIDA
I've noticed that my Maida regulators drift with temperature -- LB47 has a compensated circuit using the LM329 -- here's how to implement -- first the schematic:
Here's a single layer version free for the pickin'
Old 5th May 2009, 12:24 AM   #2
Jack,
Can you send me the file on this, I will try to make one by hand.
Bill
Old 5th May 2009, 01:54 AM   #3
okapi is offline okapi  United States
okapi's Avatar
Hi Jack,
can i ask what you need the high voltage for?
thanks.
Old 5th May 2009, 12:47 PM   #4
jackinnj's Avatar
Originally posted by wirewiggler
Jack,
Bill
PM me your email address. I changed the voltage setting resistor to consist of 2 units -- it's less expensive to use a pair of 3W devices and spread the heat.
Originally posted by okapi
Hi Jack,
thanks.
Tube preamp.
Old 5th May 2009, 02:35 PM   #5
okapi's Avatar
this is the data sheet for the Maida regulator from national (1980).
Old 5th May 2009, 02:59 PM   #6
jackinnj's Avatar
The Value of C1 should be 1uF, not 100F -- this is a recurrent problem with Multisim -- but when I translated Multisim to Ultiboard I changed the value to 100nF -- should be 1uF -- thank for pointing out the error. A 1uF pp also has a bigger footprint.
The pass transistors which Maida used are now unobtanium. The TIP50's are rated 500V and are more than sufficient for the task.
Old 5th May 2009, 03:40 PM   #7
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I just use a single IRF840 pass element.
Old 6th May 2009, 12:34 AM   #8
okapi's Avatar
unfortunately, i can't take any credit for finding an error. I was just posting the application note so that beginners like myself, who can't figure out a circuit without an explanation, could make also make use of your helpful post.
i believe you have also built the jung super reg, how does the noise level of the Maida with the lm329 compare?
Old 6th May 2009, 02:29 AM   #9
jackinnj's Avatar
Janneman, I believe, did the definitive work on the Jung super-reg. I use a smt version of the Jung/Didden in my rework of the Crown IC-150 with wonderful results.
Somewhere in the universe of diyaudio is a comparison of the Last-PAS regulator and my LR8N3 (supertex) regulator. I used a storage-scope, bandwidth limited, to integrate noise over time. I haven't put the temp compensated Maida through these paces.
The LastPAS can be a little wonky with respect to temperature and I found that the current range of HV zeners are more prone to failure than their Pb cousins.
The LastPas is a really quiet, really low impedance supply.
Old 6th May 2009, 02:57 AM   #10
okapi's Avatar
thanks for your replies. Because of this thread i have discovered 3 additional voltage regulators. I was foolish to think i had almost maxed what there was to know about "standard" linear power supplies for audio.
on a side note, i hope the new version of diyaudio moves the power supply forum to its proper place - the home page.
thermally compensated Vb bias circuit? davygrvy Solid State 0 11th January 2009 06:17 PM
Speed Compensated Volume in GM vehicles LightwaveDude Car Audio 11 11th October 2007 06:04 PM
DC compensated SE output transformer fscarpa58 Tubes / Valves 123 3rd June 2005 05:18 PM
Temp. compensated transistors from Sanken Real_Macgyver Solid State 0 12th August 2004 09:10 PM
Page generated in 0.14496 seconds (60.87% PHP - 39.13% MySQL) with 11 queries
