olá!
I mounted this circuit of SMPS, activated only 12vcc of the circuits integrated to check the wrists. did I watch with a multímetro a frequencia of 114 KILOHERTZ in the teminal 4 of the ic SG3235, in the terminals 14 and 11, they did not observe anything, that can be happening? |
#2 |
smps
#3 |
#4 |
I already mounted but did not tie the circuit of power (slide bar DC), I energized only the LM7812 that feeds the integrated ones.
but I found some strange things in the circuit. The internal oscillator of the CI SG 3525 oscillates in a frequency of 114 KHz, fact proved through the terminal 4 measured ones with frequncímetro regarding the negative of the LM7812. However no sign appears in the pins 11 and 14 of the CI, which are the exits. another thing is the drive IR2110, internally he works chaveando the gate of the chaveador, hour for VCC, Hour for negative and is there that the problem is, since the negative of the slide bar of 311 VCC is the same negative of the LM7812 that feeds all the integrated ones, the IR2110 to a chavear the gate of a chaveador for negative, which is with the DRAIN been connected straightly of the positive of the slide bar, it does so that the gate receives high tension since it closes a circuit between drain and gate with the tension of 311 VCC of the slide bar. I think that I am going to change for drive with trafo of wrist so it isolates completely the circuit. |
| The DAC development platform | peufeu | Digital Line Level | 63 | 23rd May 2009 08:37 PM |
| Sub Development | jwatts | Subwoofers | 21 | 11th June 2006 07:30 PM |
| SMPS & tube pre-amp development board. | ianl | Tubes / Valves | 2 | 10th April 2006 06:05 PM |
| Page generated in 0.08501 seconds (62.06% PHP - 37.94% MySQL) with 11 queries |
