Hi folks,
I wrote a small html-based program to help in designing power inductors. I wanted to share it just to get some feedback. I believe the program is quite self-explanatory, so I intend to write no special tutorials. If you understand the symbols/variables, you'll know how to use this. This was done relatively fast, so it might contain a lot of mistakes, but at least I did get some results out of it (surprise, since I wrote this one...). Last remark: This program calculates only some of the basic values, you'll have to find out for example the core losses from the appropriate graphs. Have fun! The Awesome calculator: www.students.tut.fi/~huusari/inductor_calc.htm
-Juha |
#2 |
I use Opera 9.24. The upper calculator does not work until the Do! button is pressed for the first time on the lower one.
Could you add rounding to the numbers? A dozen decimals appear.
I use to feel like the small child in The Emperor's New Clothes tale |
#3 |
Cool !!!
SivanandBalan |
#4 | |
This calculator was intended to serve as a quick tool to select core for a certain application. Personally I would like to have all the following attributes calculated: copper loss, core loss, temperature rise, number of parallel wires & wire gauges and whether they fit in the core window or not. However, there's usually no equations to calculate specific losses for a given core at a given frequency/temperature, so many attributes need to be inserted manually (first they need to be extracted from the graphs). I've tried to use PExprt form Ansoft, but the winding arrangements are not good at all. Instead PExprt gives good suggestions for the core. Still, I like to write these little programs myself
-Juha |
#5 |
Some updating done.
Now available as well: Calculator for two coupled inductors. http://www.students.tut.fi/~huusari/...uctor_calc.htm
-Juha |
| inductor calculator | bigpanda | Solid State | 12 | 9th April 2008 11:55 AM |
| Homemade Power Inductor??!?!?! | alirezan | Multi-Way | 2 | 17th October 2007 10:20 PM |
| Output Inductor Power Requirement | gearheadgene | Class D | 6 | 28th February 2007 03:47 PM |
| simple basic enclosure calculator for woofers ? | zuki | Subwoofers | 16 | 11th February 2005 04:41 AM |
| 2.2mH inductor in Aleph3 Power supply | vsr123 | Pass Labs | 10 | 9th April 2003 02:04 AM |
| Page generated in 0.09490 seconds (84.49% PHP - 15.51% MySQL) with 10 queries |
