Go Back   Home > Forums > Amplifiers > Power Supplies
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 24th March 2009, 04:16 PM   #1
kirtm is offline kirtm
Default monitor voltage input
I have been tasked to design a piece of test equipment to test an Lm338 circuit used as a current limiter. I would like to monitor (LED?) a variable input supply (+4 to +20VDC) (2.0A) through a switch that would supply the LM338 circuit. Something that would show that power was supplied to the circuit. Any suggestions? Thanks.
Old 10th April 2009, 04:28 PM   #2
Fuzzymuff's Avatar
Default c here
http://sound.westhost.com/project60.htm
Wrap it in foil, and plug it in.
Old 10th April 2009, 05:55 PM   #3
AndrewT is offline AndrewT
a LED with a couple of series diodes and a resistor (3k) will do that.
The 1.6V LED (red) + 1.4V (two diodes) will be off @ <=3V.
At maximum voltage it will be very bright. At minimum voltage it will be very dim.
You could replace the two diodes with a two terminal CCS. Buy a 5mA CCS it will show constant brightness >=6V and dim as 4V approaches.
regards Andrew T.
Thread Tools
Monitor input level Mickey-2002 Digital Source 0 26th July 2006 02:32 PM
Page generated in 0.12611794 seconds (73.23% PHP - 26.77% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
