#11 |
What is the peak current demand of an 8ohm speaker? 200W into 8r0 approximates to 7.1Apk for sinewave power. An 8ohm speaker can require three times this, i.e. 20Apk on fast transients. Where can that current peak come from? Can some of this demand be met by the decoupling close to the output stage? What is the peak transient current that is permitted in a warm or hot 3055? How many 3055 are required to meet the remaining peak transient current demand of that 8ohm speaker.
regards Andrew T. |
#12 |
Hi, we will be running a maximum of 150w into an 8 ohm speaker, or 300w into 4ohms.
There is 8,800uf of decoupling per rail, for 6 LM3386, running at 30V rails. The continuos collector current of each 3055 is 11A @ 50C. |
| Lost Thread-High VOltage Regulated Power Supply | LinuksGuru | Tubes / Valves | 2 | 21st June 2009 01:48 AM |
| regulated power supply for high powered amps. | marchel | Solid State | 14 | 5th March 2009 09:00 AM |
| Links to High Current Regulated Power Supply? | lgreen | Solid State | 1 | 25th January 2005 12:11 AM |
| high-voltage regulated dual power supply | zzz | Solid State | 1 | 17th September 2002 01:15 AM |
| Page generated in 0.05890 seconds (67.03% PHP - 32.97% MySQL) with 10 queries |
