Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd March 2009, 08:19 PM   #1
jman 31 is offline jman 31  United States
jman 31's Avatar
Default Bipolar Variable Power supply for protoboard
I guess the title says it all. I want to build a bipolar variable Power supply somewhere between 5 and 30 dc volts that I can plug into my protoboard for various projects. I was looking at THIS ONE, but I wanted something that was variable on the spot. If someone could point me to a good one I would really appreciate it.
Jman
Old 23rd March 2009, 10:38 PM   #2
mjf is offline mjf  Austria
hello.
simple and classic: have a look at power supplies with lm317/lm337 variable regulators (for preamp projects and so.....)
greetings...........
Old 23rd March 2009, 10:52 PM   #3
AndrewT is online now AndrewT  Scotland
try this Forum.
regards Andrew T.
Old 23rd March 2009, 11:15 PM   #4
jman 31's Avatar
Originally posted by AndrewT
try this Forum.
Wow, never would have thought of that. I did a search but I didn't really have any parameters other than the title of this thread. I will do it again now that mjf has given me a meaningful response.
Old 24th March 2009, 12:13 AM   #5
TechGuy is offline TechGuy  United States
Your better off purchasing either an open frame or closed frame switching power supply. A commerical product will include over-current sensing, provide multiple voltages and have a higher current output.
The LM317 LM78xx are really designed for very low output current, and can't handle large voltage differences been in the input voltage and the output voltage.
Here is a low cost Open Frame SMPS from Artesyn
Mouser 826-NFS40-7608J $49.22
The only import feature is make sure the power supply you choose can operation with no load. look for PS that can operate at 0A (ie 5V 0-3.2A). Otherwise you need to attach a resistor to produce some load. SMPS that have a minimum current load will switch immediately off, if there is no load present at power on.
Old 24th March 2009, 09:34 AM   #6
"voltage regulator" brought up 3201 threads.
"variable voltage regulator" brought up 136 threads.
Start searching instead of just clicking "I have searched" icon
regards Andrew T.
Old 24th March 2009, 12:13 PM   #7
jman 31's Avatar
OK so your one of those. I get it. I searched "bipolar power supply breadboard". three results. None that helped. Have you ever realized that sifting through 3,201 threads or even 136 threads to try to find exactly what you are after is a daunting task. What does it hurt to ask directly about a certain item instead of guessing which one is the right one for me. And if you don't want to help, don't!
Old 24th March 2009, 01:18 PM   #8
You haven't given enough information. How much current does it need to supply? 100mA? 500? 5 amps? Tell us that, and maybe we can tell you what you want to build.
Old 24th March 2009, 02:50 PM   #9
jman 31's Avatar
Sorry about that. You are absolutely right. Mostly what I am doing is small 9 volt projects. Stompboxes for guitars, headphone amps, and the like so I would say 100ma would cover it. I probably really only need it to cover up to about 18v.
Old 24th March 2009, 03:36 PM   #10
hello.
i think there are some examples in the datasheet of the lm317 and lm337.................
greetings...............
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 08:24 PM
Variable Pc Power Supply-2 (part1) 1..30v 0.15..6a gev Power Supplies 0 7th January 2008 08:46 PM
simple bipolar power supply BodomChild Power Supplies 4 12th July 2006 08:25 AM
Digital Variable Power Supply jleaman Digital Source 13 13th April 2004 11:09 PM
Variable AC Power Supply Rino odorico Everything Else 10 4th September 2002 10:19 PM
Page generated in 0.10635 seconds (77.01% PHP - 22.99% MySQL) with 10 queries
