sync of SG3525
I want to sync two SG3525, clocked at 75Khz with a separate oscillator running at 85Khz. I plan on using two opto couplers connected to the sync pin of the 3525 with a resistor between the sync pin and +Vcc. Will this work reliably or do i need to use a buffer between the opto and the sync pin. Any info shared on this topic will be appreciated.
Trevor-
The only Application Note I could find is one from Silicon General, PS-7, "Synchronizing the SG1525A PWM". Section 1 of this sheet (Synchronizing One Device to an External Clock) is as follows:
[A. Program the SG1525A oscillator with R(t) and C(t) to free-run at a frequency 10% slower than the external clock frequency.
B Drive the SG1525A SYNC pin terminal (pin 3) with the external clock. Input impedance is 2k. The clock amplitude should be greater than 2 volts and less than 5 volts. Pulse width should be at least 300nS for reliable triggering, but should not exceed the free-running oscillator clock pulse width by more than 200nS.]
Since you want to synch the '3525 at 150kHz, these times should not present a problem. If you were synch'ing it at the 300kHz, you might run into some problems, as the '3525 oscillator's max. frequency is ~400kHz.
EVA is right that there are some things that can't be learned from datasheets alone. I've looked everywhere for anything I can find on synch'ing the SG3525, MC33025, TL494, UC1846, and other popular PWM chips, and this Application Sheet is the best thing, by far, I have seen for the SG3525. I have worked on an "Application Note" of my own to consolidate the synch schemes for all of these chips so I can see them all at-a-glance. If I get some time, I will scan it and post it.
I got this sheet some time ago (before the www), so I have not gone to SG's website to see if it has made it into cyberspace yet.
Hope this helps,
Steve
Happy to help out. Do the two '3525s need to be Galvanicaly isolated? If not, then you can sync 'em much easier w/o the opto. I wouldn't try to send a 75kHz signal thru the opto simply because if it's slow speed. I do not have any schematics or reference material on sync'ing thru an opto. If I can somehow scan the PS-7 App Note sheet and post it. I will try.
pulling out thread from the dust ...
Hello all,
I find mistake in SG3525 datasheet, the comparator have wrong polarity transistors. I did simulation because still cant figure how to synchronize two or more of them. I have spice model for LTSpice, but i am not sure in accuration of the model in osc section.
I will do some tries, include hardware. But if someone have real circuit with use of these SYNC and OSC pins, i will be grateful ....
There is just an idea in second picture - terminate the slower cycle with pulse from fastest one. But still without this SYNC pin.
I have error in Rt wiring. Rt must be grounded.
No matter, here is the answer. May be require buffering and line impedance matching, but the idea is clear.
I need this for current sharing, may be i will make a thread if someone shows interest ...
