Right my understanding of push-pull is that the voltage swing is split between 2 channels which amplify either half (maybe not the best description...), couldn't you invert the phase of one channel so there's not harmonic cancellation?
#2 |
At least somewhat, so long as the duty cycle is set to maximum, if I understand you. But normally the 180 degree phasing is beneficial for greatly reducing current peaks.
#3 |
Are you asking about transformer-coupled audio amplifiers or switching power supplies?
I use to feel like the small child in The Emperor's New Clothes tale |
#4 |
Audio amplifiers. I was thinking of how to improve harmonic spectrum of push-pull amp types like AB.
| Push-Pull using only N-Channel MOSFETs | Kashmire | Solid State | 32 | 6th August 2009 01:48 PM |
| The difference of Push-pull,Half-bridge,Full-bridge | digi01 | Chip Amps | 0 | 8th September 2006 02:10 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| problem: half power on push-pull ? | vlljpior | Tubes / Valves | 5 | 12th March 2005 05:38 PM |
| In push/pull woofer mounting, Why Vas will be half that of single driver? | haggy | Multi-Way | 7 | 10th December 2001 02:29 AM |
| Page generated in 0.08366 seconds (73.61% PHP - 26.39% MySQL) with 10 queries |
