Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th March 2009, 05:38 PM   #1
Default Confused about transformers
I have a toroidal transformer with dual (30v) secondaries for my power supply (Hammond 182P30) I'll be using a single bridge rectifier into four large caps. I'm thinking the "hot" side of each secondary wires to the rectifier, and the neutral wires connect to the ground plate between the caps. Is this correct?
Old 12th March 2009, 05:44 PM   #2
DougL is offline DougL  United States
A drawing would be priceless in this instance.
The answer as it stands is "I think so, but I am not sure"
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 12th March 2009, 06:07 PM   #3
According to hammond documentation
blue & gray link and used as center tap
red to rectifier
yellow to opposite side of rectifier
Old 12th March 2009, 06:08 PM   #4
leadbelly's Avatar
Default Re: Confused about transformers
There is no such thing as a neutral secondary, unless you've done something wrong like wired one of the secondary's leads back to the mains neutral.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 12th March 2009, 06:13 PM   #5
post3 shows the tapping to ground between the caps and the centre tap.
No, take the tapping from the junction of the caps to the main audio ground.
The current passing along the centre tap to the caps is in short duration high current spikes. Don't let this contaminate your main audio ground.
regards Andrew T.
Old 12th March 2009, 06:18 PM   #6
The post was only to give correct color and phase for transformer not layout or ground loops.
Old 12th March 2009, 06:54 PM   #7
leadbelly's Avatar
I agree. AFAIK schematics were never intended to convey layout instructions.
Old 12th March 2009, 10:01 PM   #8
Thanks for the info, Audiofan....I hate to be guessing when it comes to this stuff!
Old 21st March 2009, 01:29 PM   #9
I would hate to be reading an obituary because someone was too embarrassed to ask.
Fools go in uninformed.
The rest of us survive.
regards Andrew T.
Confused about DVC and Q mashaffer Multi-Way 13 30th July 2006 03:40 PM
i'm confused ... sss Multi-Way 5 11th May 2006 12:03 AM
Confused! alieas_neo Car Audio 2 1st May 2004 06:45 PM
I'm Confused and I need your help. Paprika Solid State 12 22nd September 2003 07:49 AM
Page generated in 0.11209 seconds (75.18% PHP - 24.82% MySQL) with 11 queries
