Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th March 2009, 02:24 PM   #1
Send a message via AIM to shon35us Send a message via MSN to shon35us Send a message via Yahoo to shon35us
Default SMPS question
how to insulate primary leads
Old 5th March 2009, 03:25 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
?? from what?
you should write more... what do you need to do that?
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 5th March 2009, 04:39 PM   #3
how to insulate the primary from the secondary output
Old 5th March 2009, 05:36 PM   #4
infinia is offline infinia  United States
infinia's Avatar
8 mm creepage distance, or approved double insulation
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 5th March 2009, 05:52 PM   #5
Default so....
don't use electrical tape?
Old 5th March 2009, 05:56 PM   #6
infinia's Avatar
No, really can't depend on it.
tell me what you are doing. Xfrmer or what?
Old 6th March 2009, 08:17 PM   #7
looking to make a smps +/- 22v at 12 amps, I was going to hand wind the secondary but I'm looking for something protect them from each other
Old 6th March 2009, 09:08 PM   #8
infinia's Avatar
I'm still not understanding what you're doing. Them=dual secondarys from each other? Mostly all switchers xfrmers are handwound.
3M makes tape for this purpose in standard widths for the most popular bobbins like ETD. Your magnetics distributor can point you in the right direction. If the tape is not the correct width, your build up gets too high to support the 4mm overlap in a continuous tape wind.
Use 4mm margins from each of the windings to bobbin walls. Approved tape in the correct width will be at least > 2 layers min.
Secondaries lower than SELV do need additional insulation from each other.
Old 6th March 2009, 10:10 PM   #9
I will do more research, thanks
Old 13th March 2009, 11:45 PM   #10
TechGuy is offline TechGuy  United States
Teflon tape or non-metalized mylar (polyester) works. Teflon and Polyester have high breakdown tempertures and also have fairly high breakdown voltages. More expensive films and tapes that can be used are Polyimide and Nomex. These have very high thermal breakdown tempertures, and ideal for transformers operating in severe conditions.
As infinia discussed you have to becareful with uneven overlapping when you need to wind many layers as the overlap will cause the layers to become uneven, which will eventually make it impossible to add layers without large gaps (causing exccessive Inductance leakage aka large voltage spikes,, and lower coupling efficiency).
If your just putting together a simple experimental low voltage prototype, you can also use Kraft Paper or even plain copier. You can increase the dielectric value of the paper by applying a coat of polyurethane to plastize the paper (brushed on). You cut the paper to match the size of spool so that there are no overlapping.
I also recommend applying a coat of electrical varnish (or at least polyurethane or polyurethane glue) to each layer to secure the windings and to reduce audio noise when the transformer is operating. Windings that are not secured will vibrate at the switching frequency and generate noise. This vibration can also rub off the enamel insulation over time. OEM transformers are usually use vacuum impregnated varish to secure the windings. The transformer wounded spool is sumerged in electrical varish in a vacuum chamber, when the air is vacuumed out of the chamber it pulls out the air between the windings. When the air is let back in to the chamber, varnish is pulled into to all of the gaps and holes in the windings. Then the spool is baked to set the varnish.
Polyurethane isn't electrical varnish as it has a much lower breakdown temperature, lower thermal conduction value, and lower diaelectic value. However its better than nothing. Dow Corning manufactures electrical varnish, but its not cheap and its difficult to obtain from distributors in small quantities. It also has a shelf-life of a few years.
SMPS question shon35us Everything Else 0 5th March 2009 02:23 PM
SMPS question funky2x Power Supplies 5 23rd June 2008 11:34 PM
SMPS :noob: question Low Rider Power Supplies 1 27th March 2008 03:17 PM
PC smps Question nicoch58 Power Supplies 19 25th November 2006 12:41 AM
question regarding SMPS and UCD cowanrg Class D 0 26th October 2005 06:19 AM
Page generated in 0.16226 seconds (37.02% PHP - 62.98% MySQL) with 10 queries
