Isolation after transformer considered isolated?
Old 1st March 2009, 05:44 AM   #1
firethorn is offline firethorn  Singapore
Default Isolation after transformer considered isolated?
Hi guys.
I'm building my next power supply and I need to clarify something.
If I parallel multiple rectified AC after a transformer's secondary , is it considered isolated?
I originally intended to use 1 transformer for each output but I find that it's a waste of money and space due to the low current I intend to supply for about half of the 10 outputs.
e.g.
Code:
AC->(1) Rectified DC->Smoothing+Filtering+Regulation
  ->(2) Rectified DC->Smoothing+Filtering+Regulation
  ->(3) Rectified DC->Smoothing+Filtering+Regulation
  ->(4) etc
Old 1st March 2009, 05:48 AM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
I for one have no idea what you are trying to say. How about a sketch?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 1st March 2009, 06:39 AM   #3
Haha... I myself thought I sounded cryptic..
Apologies for the bad drawing. I can't draw for nuts, on a computer AND in real life. haha.
Is the schematic below considered "isolated" or isolated? There is only 1 secondary.
Old 1st March 2009, 06:47 AM   #4
star882 is offline star882  United States
star882's Avatar
Use a flyback converter with a separate winding for each of the outputs. It can be designed to operate from low voltage if you are new to power supply design.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 1st March 2009, 08:23 AM   #5
isn't that usually part of an SMPS circuit?
means i have to read up on this.. man.. SMPS are way out of my league at the moment.
But I didn't know that flyback converters are isolated till now. Interesting.
Old 1st March 2009, 09:31 AM   #6
Electrone is offline Electrone  United States
Isolation is with respect to the mains service; so it is isolated.
Old 1st March 2009, 11:46 AM   #7
I mean with regards to ground loops. Not in terms of safety. Is it considered isolated in that respect?
Old 1st March 2009, 12:59 PM   #8
My experience with personal equipment has involved ground loops being caused by interaction with the mains. Yet there is just about an infinite number of possible set-ups. Maybe just try minimalism and address problems as needed.
Old 1st March 2009, 01:02 PM   #9
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
You seem to miss something elementary.
3 times 9V supplies are not isolated in any way, because you achieve isolation by magnetic (or optical) coupling only. Keep in midn that normally you connect GND to one of secondary wires.
But you can achieve ground loop braking by some common mode filtering, I mean if you put R+L on both wires of rectified voltage and C between them after RL.
---/\/\/\/---ununun---|----------
............................___
........................... ___
Old 1st March 2009, 01:49 PM   #10
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
You are allowed one isolation card with that scheme. When any one of the 9V commons gets tied to ground, the others automatically follow this reference, though you need to understand the others do not have their commons directly connected to ground, nor are you permitted to. Nor does the measured common-ground voltage on the other supplies equal zero, it is somewhat dynamic and variable.
So, as long as you have no ties to ground on the secondary supplies, they are isolated from ground and from the mains voltage. But they are never isolated from each other, they are bonded together through the p-n diode junctions.
You only get one opportunity to ground a secondary. So with regards to ground loops, it will fix the bonded secondary, but I doubt you will like what happens to the others.
Isolation after transformer considered isolated?Hide this!Advertise here!
Transformer Isolated USB? TheSeekerr Digital Line Level 12 15th May 2009 11:03 PM
Isolated Transformer kof Power Supplies 4 28th December 2008 12:51 PM
