Best low noise regulator?
Old 27th February 2009, 09:49 PM   #21
syn08 is offline syn08  Canada
Default Wiring
This is how I'm wiring this regulator. If the regulator is in the same case with the phono stage you may delete 3 and the shielded cable T1, and simply star the output/sense and the grounds/sense at the low noise input stage terminals.
I guarantee that using this schema will improve the performance. Can't say about the sound, but if there's any impact it will definitely be larger than the effect of an overnight burn-in. Also, if the MOSFET you are using hass Ciss lower than the NTP in my schematic, you may want to proportionally increas the gate resistor, to keep the pole unchanged.
Old 28th February 2009, 07:06 AM   #22
Rtop84 is offline Rtop84  Poland
Put resistor between inverting input and voltage ref source to isolate it from cap.
Best regards,
Rafal
Old 28th February 2009, 08:36 AM   #23
R.I.P.
Syn,
why have you duplicated the route 3 and route 4 to the load sense point?
This is one of the very rare occasions where the designer has properly drawn the schematic to show how to implement connections/traces that ensure the design works as intended.
I do wish all designers would do this.
Uchi's extra resistor should be 125r to match impedances at the two opamp inputs.
But, this value only applies if the effective impedance of the LED ref is zero.
Any idea what the LED ref impedance is?
regards Andrew T.
Old 28th February 2009, 09:36 AM   #24
Originally posted by AndrewT
Syn,
Because you don't want any DC trough the shielding. 4-4 should have a lower impedance, so current goes through there. Another idea is to leave the right 3 open, but I usually prefer to connect both ends.
If possible, I would avoid the 125 ohm resistor. It adds noise to the output.
You are correct, e.g. without proper wiring something like the PGP amp would never be possible. See the wiring schematic on my web site http://www.synaesthesia.ca/Wiring.html
Edit: As it is, the output voltage is about 30V and of course, the raw power supply has to provide at least about 35V. You may want to adjust the R3/R4 divider for other values.
Old 28th February 2009, 05:39 PM   #25
martin clark is offline martin clark  Europe
When I've used LEDs for voltage reference purposes (at 1-3mA) I've seen impedances c.35-50ohms. Pretty low actually, and significantly better than a zener at these currents
Old 1st March 2009, 01:46 PM   #26
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
hi syn08
After examining your circuit again i have to admit i don't quite understand it and will appreciate some hints.
1. Why bypassing R5 important for the high frequency performance? Is R5 not there simply to supply current for the voltage source? And presumably can be replaced with a ccs for better performance?
2. Why is the connection from R5 taken to the sense point? I understand the connection to R4 but again, is R5 not simply supplying stable current to the led?
3. I would probably not ask 1 and 2 if i could get the circuit to work as shown, but i can't. As soon as there is a cap above 100n across R5 i get low-frequency oscillations seemingly determined by the LED impedance and the cap.
I don't know how important any of this is. Fed from a ccs instead of a resistor this shunt sounds quite spectacular.
Old 1st March 2009, 02:35 PM   #27
Originally posted by analog_sa
hi syn08
1. If you think in terms of sound, I have no explanation. Otherwise, the output impedance and the line regulation are both much, much better with R5 bypassed. Think of the caps as being included in the loop and the opamp acting as a capacitor multiplier. See the next two messages for results.
2. For the same reason as above. See also the Jung regulator articles, they use the same schema for connecting the reference current source.
3. I'm pretty sure you have grounding issues. From my experience, it is also unlikely you'll ever have good performance for this regulator built on a breadboard. Try point to point with short connections.
Old 1st March 2009, 02:37 PM   #28
Default Line regulation, LED bypassed
Old 1st March 2009, 02:39 PM   #29
Default Line regulation, R5 bypassed
Line regulation, R5 bypassed. Which one would you take?
Vertical scale is in dB.
Old 1st March 2009, 04:16 PM   #30
analog_sa's Avatar
Line regulation is something i largely don't care about. Plus i have preregulators. Do you have similar pictures for noise?
Best low noise regulator?Hide this!Advertise here!
Reducing regulator noise. Predator864 Power Supplies 3 23rd March 2008 07:26 PM
Regulator Output Noise Voltage Spec TerryC Parts 2 23rd January 2006 04:46 AM
wanted: suggestion for a low noise regulator circuit. Raj1 Digital Source 8 30th January 2004 06:55 PM
Ultra low noise JFET voltage regulator Kochkurov Maxim Digital Source 6 25th January 2004 11:33 AM
ForSale: LT1085CT Low noise Regulator tone Swap Meet 0 10th September 2003 06:22 AM
