Best low noise regulator?
Old 3rd March 2009, 04:37 AM   #91
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Originally posted by Bonsai
Its no good simulating the output load with a sine wave - you need to use a square wave to see how the regulator responds to fast transients. This will let you get an idea of how your loop is compensated and whether it needs tweaking (you won't get the absolutely correct answer from the sim, but the sim will help you understand what is going on in the circuit and where th e best place is to tweak). The last thing needed on a high performance reg whether shunt or series pass is overshoot or ringing on load or line transients.
That's true, but it's also true that the regulator is relied upon only in the region < 100kHz. The large bypass capacitor is in use from 100kHz to several MHz, and the small bypass capacitors handle frequencies from a few MHz up to 1GHz, where the mutual capacitance of the power planes handles the remainder. In my opinion, it's irrelevant how a regulator performs for load steps with rise times less than 10Ás.
Also if you have large input transients you have a major architectural problem with your circuit!
That said, I think the Jung has creditable transient performance. Here, for instance, is the response to a 1V transient with 1ns rise time on the input.
Old 3rd March 2009, 04:39 AM   #92
jwb's Avatar
Response to load transient with 1ns rise time.
Old 3rd March 2009, 04:40 AM   #93
jwb's Avatar
And finally, response to load transient with a 10Ás rise time. All fairly good. The trick is to have a good PCB layout so you achieve these performances in reality :-)
Old 3rd March 2009, 04:52 AM   #94
Bonsai is offline Bonsai  Europe
Looking at your last post, if I'm reading it correcly I'd say you have problems. There should be no overshoot or ringing.
Using a rise time of 1ns is not practical.
Use a few u seconds.
Old 3rd March 2009, 04:56 AM   #95
The reason to test with a step or square wave input is to se e how th e circuit behaves wrt to line noise - and you do get spikes and straight HF noise coming through much more than you would believe. How does your cuircuit behave unde r thes e conditions - does it pass th e nois e straigh t through? does it oscillate? Its easy to deal with DC or low frequncy input voltage shifts, but at higher frequncies this is another matter.
Old 3rd March 2009, 05:07 AM   #96
jwb's Avatar
The last post is with a 10us rise (fall) time.
Old 3rd March 2009, 08:13 AM   #97
MRupp is offline MRupp  Germany
MRupp's Avatar
There are zeners with substantially lower dynamic Z than LEDs these days. I just bought a box full of 6.2V zeners with 9Ω dynamic impedance at 5mA.
FWIW: According to the book - and here I actually mean "Valve Amplifiers" by Morgan Jones - cheap red LEDs and infrared LEDs should have impedances in the range of 5 - 6 Ohms, and the new and brighter LEDs of varying colours obvioulsy have higher impedances. I think LEDs like healthy currents of 10 - 20 mA to be at their optimum (Zeners btw. too). Off course, this is all written lore and not my personal measurements.
Martin Rupp
Old 3rd March 2009, 08:48 AM   #98
keantoken is offline keantoken  United States
keantoken's Avatar
Hi all. This is a very interesting thread.
First of all,
http://www.diyaudio.com/forums/showt...05#post1759105
The 2N6387 is a power darlington! Is this an error?
I have a simple and brutal circuit here which should suffice.
Lastly, Does anyone want to take a poke at a Rush Cascode based Shunt or Linear regulator? Here is my little stab at a shunt regulator (attached). Input regulation is very good but not as good as my linear version, which I will post if anyone wants to see it... I have not tested this circuit in real life.
I know someone will complain about thermal drift but really, is a perfect 12V output voltage at all times that important for an amplifier?
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 3rd March 2009, 09:02 AM   #99
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Bonzai,
A test with a sine sweep to some high frequency showing curves of magnitude and phase against frequency gives you the same info and is often easier to interprete. I can see for instance that PSRR decreases to say 20dB at say 100kHz, or that pphase shift reaches 180 degr at say 200kHz. Looking at a ringing sq wave doesn't give me so much quantitative info. But I guess it's also a matter of personal preference.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 3rd March 2009, 09:09 AM   #100
Jan,
for the measurements you mention I do not disagree (you can alsodo a straight AC gain and phase plot for both th eoutput and input). I do these to get this info. For loop stability and feedthrough, I prefer to use a squarewave load or a squarewave on the input.
Best low noise regulator?Hide this!Advertise here!
Reducing regulator noise. Predator864 Power Supplies 3 23rd March 2008 07:26 PM
Regulator Output Noise Voltage Spec TerryC Parts 2 23rd January 2006 04:46 AM
wanted: suggestion for a low noise regulator circuit. Raj1 Digital Source 8 30th January 2004 06:55 PM
Ultra low noise JFET voltage regulator Kochkurov Maxim Digital Source 6 25th January 2004 11:33 AM
ForSale: LT1085CT Low noise Regulator tone Swap Meet 0 10th September 2003 06:22 AM
