It seems the voltage scale is somewhat weird?
yes, should be "Volts/RtHz"
with Cset=22u
It seems that the Sulzer measurement has the same problem that
Scott Wurcer spotted with my preamp: it is not 1/f.
Have the measurements all be done with the same setup?
All the measurements were done at the same time with the SSM2019 balanced preamplifier at a gain of 100. The AP has a filter factor of √0.2316 * F in the analog mode. So I wrote an AP basic macro to plot Volts/√Hz.
As a sanity test, I ran the tests and compared numbers to those in his 1995 articles. They seem to compare closely, although he was able to measure impedance lower than I witnessed.
with Cset=22u
What implementation, circuit board wise, did the LT3042 enjoy at the time of your measurement?
used a graphing program to take the data off the LTC datasheet.
Good. It is nearly meaningless to compare results copied together from
unspecified sources. That's why I did the series on lab supplies, references,
regulators and batteries.
The GR-noise-like appearance of the noise in the Sulzer does not need
to come from the measurement system, it can be just as well in the regulator
itself. From the circuit I just found on the tangentsoft site
< Op-Amp Based Linear Regulators >
I would guess that we just see the noise voltage of the 47K-resistor to the ninv-input
of the op amp that is not good enough filtered for really low frequencies by
the 1uF tantalum. That is easily and cheaply cured.
The -3dB frequency may be 3 Hz, but at -3 dB Xc is just == R, so there
is not much shorting of the resistor's noise voltage.
I must confess that I did the same mistake in the input coupling of my preamp
and Scott spotted it immediately.
Reading the website article, I find it kinda funny how names are attached to
textbook circuits and they are carefully updated, as if soldering a LM317 in front
of another regulator was the culmination of patent-worthy IP that required
a new name. That does not apply to the Jung reg.
regards, Gerhard.
Are there similar comparisons made for output impedance (which is probably often a more important parameter)?
check out the download section on www.linearaudio.net
My experience with 5V integrated regs in digital
I found LM2940T5 best in a multiple integrated reg comparison.
See http://www.diyaudio.com/forums/digi...c-kit-cs8416-ak4393-5532-a-6.html#post2541019
I would use a LT1086-5
Oops. Didn't read my own post carefully. That is National LM340T5 that came out on top.
Thanks Sorr and Steely for the help.
Use an LT3042 and an outboard PNP or NPN transistor. The LT1086-5 isn't even remotely in the same ballpark.
Suggestion for a complementary rail?
I have made a tiny layout for the npn circuit in the data sheet.
I have no idea of a negative version that does not have at least
2 op amps.
It will take some time until I can test that. A lot of stuff in the pipeline
in front of it.
regards, Gerhard
I thought he just wanted to unsolder the existing 3 reg and replace it another, but better 3 pin reg.
- Power Supplies
- Best low noise regulator?
