Best low noise regulator? - Page 22 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th March 2009, 06:50 AM   #211
Onvinyl's Avatar
here I proposed a variation of jwb's circuit. It is indeed good on paper. I had sometimes difficulties with square wave response behaviour (due to its high gain I think), though.
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 12th March 2009, 02:08 PM   #212
iko is offline iko  Canada
iko's Avatar
Originally posted by jwb
You didn't leave out the base stopper on my Q3 did you? Without that it does certainly oscillate easily. I have it breadboarded here and it's not oscillating, or it's oscillating at a frequency well above 400MHz.
Stopper was in place, of course. I should say that I didn't have the BCW68G and 2n2907 so I used 2n2905a and bc560c respectively. In simulation both work well. Oscillation was below any megahertz value, visible on the oscilloscope. Have you implemented it using exactly those parts shown in your schematic?
Old 12th March 2009, 10:58 PM   #213
Default Re: Line regulation, R5 bypassed
Originally posted by syn08
Line regulation, R5 bypassed. Which one would you take?
Vertical scale is in dB.
I take it some simulators don't actually do checks to ensure that a circuit will actually work.
There is something wrong with the model or simulator if it describes the performance you quote here.
Firstly the voltage reference setup by the LED on the op-amp -ve ip is about 1.1 volts (ref. to data sheet) with around 3.4mA through it. That is (17V(reg)-1.1V(LED))/4k7. The dynamic impedance of the LED at this current is around 11ohms. C246 and C220 are incorrectly placed in the circuit. They will increase +ve feedback to the reference possibly introducing oscillations but also give some current compliance issues into the LED for AC conditions. With them removed there is a supply rejection ratio of around 52.6dB at the reference. This can be improved by using a current source in place of R296 but may not offer much improvement sonically.
The DC gain of this circuit is not right for a 17 volt op. With the LED at 1.1V and the gain setting ratio of R242-R243 the o/p is 27.9 volts. R242 should be 1k88 for 17V o/p
What about the noise. Yes, as some OP mentioned the gain setting loop resistors give gain which includes i/p referred noise gain as they always do in traditional feedback type amplifier circuits. The predominant noise sources in the circuit will be the LED, the op-amp input noise and the resistor noise R243//R242.
AC bypassing R242 will reduce HF noise but may increase instability if the op-amp is not stable at low closed loop forward gains.
Some further noise reduction for the LED reference could be done using an RC network.
Some extra stability (phase margin) could be achieved by placing a parallel LR circuit in series with the reg o/p and the decoupling caps and load.
I would prefer a bipolar for the shunt element due to its lower inter electrode capacitances and therefore better phase margin and stability.
Old 13th March 2009, 01:38 AM   #214
iko's Avatar
Craig, I cannot agree more with you about the disparity between simulation and reality. I still do quite a bit of simulation to test out ideas, but always go to the soldering iron for a reality check.
If you feel like it, would you please comment on the circuit attached? While it is not the most extraordinary in simulation it does have good results there too. However, in reality it performs very well. (For outstanding simulation results I posted a circuit earlier, unreal, really.) Do you see any possible areas where we could improve? Thanks in advance.
Old 13th March 2009, 02:19 AM   #215
It's great to see all these nice simple ccts that do the job well and also sound good.
Perhaps the R4 could benefit from some more attention.
Add a small resistor (0.1 - 1 ohm) from o/p rail to M2 so you can actually measure the shunt current - won't effect the result.
IRFP9610, etc?
Have youb tried feeding this with a simple series reg (low ripple), or alternatively, with a Cmultiplier (high Z)?
Generally, good sound results for small number of extra components.
Old 13th March 2009, 04:26 AM   #216
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
ikoflexer, you were right about the oscillation. Mine was free-running at about 10MHz. That was with PN2907A in both positions. Shame about that.
I tried your and it looks solid. No oscillation, good transient load response. Wasn't able to measure the input ripple rejection.
Old 13th March 2009, 02:31 PM   #217
iko's Avatar
Let's not lose hope jwb, perhaps it can be fixed; it looks so good in simulation. I can confirm that I could not stop it from oscillation, and I've tried a number of things. You're probably a step away from great success.
This other circuit, the "solid" one, you can blame salas for the original design I only tweaked here and there. This is the one I am using at the moment, it is appealing on many levels; in fact I couldn't stop using the prototype. BTW, have you listened to it with your "noise" headphone thingy? With a proper board layout and case should be even better. PCB layout design may be in the works soon (for through the hole parts), but I'm also personally thinking of going the smd route for this one; maybe.
I'm also thinking of putting together a Dennis Colins noise amp, as I'm having problems gauging the performance of this regulator.\
Let's keep the fire going, good discussion, thank you all for your comments!
Old 13th March 2009, 08:51 PM   #218
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I plea guilty!
Old 13th March 2009, 09:46 PM   #219
jwb's Avatar
By the way, I didn't use the gate stopper from Post #198, and I didn't see any oscillations. I am using the IRF9610 FET.
Old 14th March 2009, 12:02 AM   #220
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Whatt is the purpose of C1 in post 214?
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Reducing regulator noise. Predator864 Power Supplies 3 23rd March 2008 07:26 PM
Regulator Output Noise Voltage Spec TerryC Parts 2 23rd January 2006 04:46 AM
wanted: suggestion for a low noise regulator circuit. Raj1 Digital Source 8 30th January 2004 06:55 PM
Ultra low noise JFET voltage regulator Kochkurov Maxim Digital Source 6 25th January 2004 11:33 AM
ForSale: LT1085CT Low noise Regulator tone Swap Meet 0 10th September 2003 06:22 AM
Copyright ©1999-2017 diyAudio
