#131 |
I would think that using the current source in the place of R6 would immediately give a huge gain in loop gain and a huge gain in performance. The 10 ohms would then need to be like 60 ohms, of course.
Syn08, what do you think? Jan Didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#132 |
diyAudio Chief Moderator
Gimme your best upgrading ideas and I will surely try them. But I forewarn you...My top criteria is always that elusive anti engineering sanity, non cross checked thing, ''sounds better or not''.
#133 | |
#134 |
Will try first chance I remake one!
Thanks! Engineers are cool!
#135 |
Until then, this is how it sims (jfet replaced R6).
#136 |
And while we're on the subject of simulation, if we're to believe any of the fiction our simulators tell us, who would like levels of line regulation like the attached?
#137 | |
I think the entire power system needs to be addressed when looking at these regulators. For example, in the project I am working on today, there is a Jung-type regulator, but there is also an array of 8 39µF OS-CON caps, 8 1µF ceramic caps, and an 800pF capacitance due to the ground planes of the PCB. Output impedance of the whole system is < 100mΩ out to 80MHz and < 1Ω out to 400MHz, which I think is acceptable considering the passband only extends to 96kHz. Regarding your comment, I agree the ringing was excessive in the plot I posted. It turns out that the AD825 has far better transient behavior than the AD820 (in simulation). I use the AD820 for low voltage outputs since it can swing rail-to-rail and run from a single 5V supply, and I use the AD825 for outputs ≥ 9V. As you can see from this plot, the transient load response is rather good. For a (quite improbable) 25mA load step with a 10µs rise time, the output swings only about 10µV. That's -68dB @ 100kHz. |
#138 | |
#139 |
True, but the models are for ±5 and ±15. Because of the 825's limited output swing, it's impractical to use it below 9V output. The 820, on the other hand, will swing down to the negative rail, so you can use it for a 5V regulator.
#140 | |
| Reducing regulator noise. | Predator864 | Power Supplies | 3 | 23rd March 2008 07:26 PM |
| Regulator Output Noise Voltage Spec | TerryC | Parts | 2 | 23rd January 2006 04:46 AM |
| wanted: suggestion for a low noise regulator circuit. | Raj1 | Digital Source | 8 | 30th January 2004 06:55 PM |
| Ultra low noise JFET voltage regulator | Kochkurov Maxim | Digital Source | 6 | 25th January 2004 11:33 AM |
| ForSale: LT1085CT Low noise Regulator | tone | Swap Meet | 0 | 10th September 2003 06:22 AM |
