Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st February 2009, 08:59 PM   #1
punkin is offline punkin  United States
Question Reclaimed transformer
Hello all,
Recently I was cleaning out the garage and came across a stack of old modems. I cracked a few of them open and started "harvesting" parts. Lots of good stuff and since these things all ran on AC power, there's plenty of power supply parts.
I have several transformer that I salvaged but cannot find any information on how they're wound. I was wondering if anyone could shed some light.
The transfromers are manufactured by XFRMS.com (I think). They have 12 pins (6 on each side). I have 4 of these.The markings on them are;
XFRMS 0608
ADTN X130T (these came out of ADTRAN modems by the way)
3531PWR045@E
I also have one additional unit which looks a bit beefier I removed it from an old computer power supply it's marked as;
MP-13B 1800
SMT-35RV-131T
DET0244(01) 0121
Any info you might have on these would be appreciated
Old 22nd February 2009, 08:46 PM   #2
Anyone?
Was hoping to be eco-friendly and make something of junk stuff. The rectifiers, capacitors and some misc hardware all seem like straightforward salvage efforts but these transformers without even simple info may be a wasted effort.
Old 22nd February 2009, 09:03 PM   #3
star882 is offline star882  United States
star882's Avatar
Do you have any pictures?
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 23rd February 2009, 09:06 AM   #4
Electrone's Avatar
Punkin, you might like to manually characterize the transformers. I suspect that there is a small power transformer and an even smaller signal coupling one in each unit. For the power one, use your ohmmeter to determine which winding is the primary. Then test the secondary, variously, with the primary powered up.
For the signal coupling one, measure the resistance of each winding. Then you can try to test for inductance estimates. I have gotten an idea of the inductance for similar transformers by placing a resistor in series with a winding and measuring the voltage drop across the winding with 60hz current applied. Saturation of the core may affect the reading.
Reclaimed Hammond H100 PSU's athos56 Tubes / Valves 5 31st March 2009 05:28 PM
How to handle Reclaimed Transformers athos56 Tubes / Valves 3 3rd February 2009 03:58 AM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.07391 seconds (72.05% PHP - 27.95% MySQL) with 10 queries
